Old 06-30-2015, 07:32 AM   #41
Wolverine 1945's Avatar
Water can get real stale,,, and bowl can get slimy !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-30-2015, 07:42 AM   #42
Flybob's Avatar
Yup. Bet your Tupperware container will have some interesting red,pink and black stuff living in it after a few weeks.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-30-2015, 07:52 AM   #43
Sounds Yummy !!!
LOL !!!
Closed system might not be quite so Bad ???
Old 06-30-2015, 07:58 AM   #44
Ford Idaho's Avatar
Sounds Yummy !!!
LOL !!!
Fresh water tank overflow tube is never closed, as is a gravity fill system.
Old 06-30-2015, 08:01 AM   #45
Flybob's Avatar
X2
Not closed. As the water comes out air goes in.
TST Tire Monitors
2 100W solar panels
Old 06-30-2015, 08:12 AM   #46
Drain the (W/H) first by removing the (Drain Plug)! If you use (Low point drains) first that can pull (White Crud Downstream)! Your Choice! Youroo!!
Old 06-30-2015, 10:38 AM   #47
cogito ergo moo
Cowracer's Avatar
As a motorcyclist, I beg of you... DON'T DUMP YOUR WATER ON THE ROAD!!!
There are two reasons why:
#1, If it has been some time since the last rainfall, there could be a significant amount of oil that accumulates in the cracks/grooves on the pavement. Your water will float that oil up and make the road as slippery as cat (poop) on linoleum, and there isn't enough water there to wash it away. You may not notice in a car, but on a motorcycle, you get an immediate sense of when things are starting to get greasy.
#2, it SUCKS driving behind somebody leaking crap. I loathe reefer tractor trailers because it seems like they are always puking something. And there is a special circle of hell reserved for people who just throw a couple of scoops of sand in the back of a open truck or even on a trailer with no tarp.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-30-2015, 11:45 AM   #48
Originally Posted by Flybob View Post
I drain everything after every trip. Most times opening both faucets then low point drains will drain WH as well. If you want to see what happens if you don't drain. Put 10-15 oz of clean water in a Tupperware type container loosely cover it and leave it sit on the counter in your RV until the next trip. Before leaving open container.
Why are you draining everything? Like I said earlier, I drain most of the water out of the fresh water tank, but that's to reduce travel weight. We like to leave a little for restroom use.
gfarmcafe is offline   Reply With Quote
Old 06-30-2015, 11:49 AM   #49
Flybob's Avatar
I was not suggesting you had to drain FW tank dry before return trip, but rather complete the draining once you get home.
TST Tire Monitors
2 100W solar panels
Old 07-01-2015, 06:19 AM   #50
Good idea to relive the pressure before you remove W/H plug !!!
Guess every would know that ???
fresh water, tank, water, water tank
