Old 05-08-2015, 08:29 PM   #1
Essential tools when camping?
For the mechanically competent among you, what do you regard as the essential set of tools? Considering weight restrictions, I don't want to bring all of my tools. But I don't want to bring nothing, either.
I'm carrying the tools required to change a tire, check lug nut torque and tire pressure and temperature. I also have a rubber mallet for wheel chocks, a hatchet, and an electric multi-meter.
What few tools should I carry to deal with issues that come up with the trailer while camping? My starting list is below. I want to keep it as short as possible. What do you suggest?
Ratchet screwdriver with multiple tips.
Channel-lock pliers
Medium adjustable pliers
Medium (10"?) crescent wrench
Squeeze tube of caulk
Duct tape (of course)
Black electrical tape
What's missing that I shouldn't leave home without?
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 05-08-2015, 08:46 PM   #2
Small container(old medication bottle) of various size screws.
marko500 is offline   Reply With Quote
Old 05-08-2015, 08:58 PM   #3
Flybob's Avatar
small multi-meter.
small rechargeable screw driver with various bits including square head.
wrench that will fit propane tank
spare bulbs and fuses
bailing wire to hold things that break / fail on the road.
tube of sealant for emergency repairs away from home
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-08-2015, 09:02 PM   #4
caper's Avatar
Volt meter
electrical connections and fuses
several patches for rubber roof
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-08-2015, 09:03 PM   #5
Cyber Phrenologist
Radio's Avatar
An assortment of fuses, 5, 10, 15, 20, and even some 30's that go in the circuits that run your slides and jack motors.
Some of those washers that go in the end of garden hoses. And some hose clamps.
One of those really cheap multi-meters you get at Harbor Freight. Pocket knife. A few wire nuts and cable ties.
Well, some of these are supplies and not tools, but you should still have them.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-08-2015, 09:33 PM   #6
mattb's Avatar
A wood splitter axe in addition to, or in lieu of your hatchet, takes less work to split and doubles as a sledge, cause ya never know. Cordless 1/2" drill, primary use for stabilizer jack moving. Extra hardware for WDH. Socket for hot water drain, again ya never know. While the ratchet drivers are handy, I prefer an assortment of phillips and slotted screwdrivers, might need that stubby. If you bring electrical crimp on terminals don't forget the strippers and crimpers. Just remember, most tools have more than one function.
2008 Roo 21SS
2003 GMC 1500HD 4X4 6.0 3:73 Diablo tuner
mattb is offline   Reply With Quote
Old 05-08-2015, 09:56 PM   #7
Hicks43's Avatar
Socket set. I have a small tool box I take with me on short trips. And the big one when we will be home for some time. That one goes in the truck. My truck is 17 years old now. Almost 300,000 on the clock
Hicks43 is offline   Reply With Quote
Old 05-08-2015, 09:57 PM   #8
Stormrider151's Avatar
Some of the motor driven systems on a trailer require a specific tool to manually retract or extend the device if there is a motor failure. They are slide outs, tongue jacks, stab jacks (electric) and awnings. Do the research and find out what they are and take that with you. I always take a collapsible ladder too. It's saved me more than once.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-08-2015, 10:02 PM   #9
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Silicone caulking for inside and Dicor for outside to be specific, matches or cig. lighter for us nonsmokers.
Edit: Almost forgot the most important hand tools: cork screw and bottle opener
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-08-2015, 10:07 PM   #10
Those are the kinds of tools I want to carry.
- 2000 Coleman Mesa
camping
