Old 07-16-2012, 09:21 AM   #11
miatared's Avatar
Before thinking it's a bad switch, test the connection with a meter. I suspect it's only corrosion.
It is a not a great lamp and it is subjected to lots to water splash and is not really waterproof, barely water resistant.
I did as the previous poster and put in a 36 LED panel, much better light, I also greased the connector with dielectric grease. Works fine now.
Ideally a marine grade lamp would be best, but these are not cheap, and truth be told, I have rarely used it...
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 07-16-2012, 11:53 AM   #12
Canadian Member
itat's Avatar
Thanks for the replies. I tested it last month by replacing the bulb with a new bulb. It didn't work. Then I shorted across the switch with a screwdriver and the light worked, so I concluded that the switch is bad. Honestly I doubt I'll ever use the light because I added a Husky electric jack that had 3 lights on it to light up the coupler area. I just bugs me that it doesn't work as intended. I'm a bit anal that way!
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
