Old 04-01-2016, 07:24 PM   #1
EZ Lube Axles/Grease Seals
Deleted. Found answer.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 04-01-2016, 07:32 PM   #2
Huh?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-01-2016, 07:40 PM   #3
f5moab's Avatar
Not sure what EZ lubes were designed for, but large boat trailers have brakes.
What I have done is after a few years of doing the EZ lube, I pull the drums and check the brakes, then clean and repack the bearings and reinstall (naturally using new seals), and add more grease.
Just make sure to ALWAYS use a hand pump grease gun, and spin the tire/rim while pumping in the grease. This has worked for me with no problems.
As for cars going 50K miles between brake jobs...that mileage is determined by vehicle and driving habits; however, on every vehicle I have owned for the past many years, there is NO bearing repacking. The bearings are not re-packed with grease or serviced as a separate part. If the bearings go, it is a complete hub replacement since the bearings are sealed in the hubs. And I believe that is true for most vehicles anymore.
f5moab is offline   Reply With Quote
axle
