Old 10-24-2015, 08:22 PM   #1
urocav2001's Avatar
Few more questions about winterizing
Do I leave the caps off the low point drains while blowing the lines out with air? Do I open them again after blowing lines out again? And I've watched some videos and they show you leave the valves on all the faucets open after putting antifreeze in the lines? Just in case something freezes.. What method do you use?
urocav2001 is offline   Reply With Quote
Old 11-01-2015, 06:05 AM   #2
bareftn's Avatar
I have a 2016 23ss roo and on the side of the camper their is a sticker that says low point drains yet I see no caps as some have talked about is that the black and gray tank valves ?
bareftn is offline   Reply With Quote
Old 11-01-2015, 06:27 AM   #3
Leave open one faucet, connect air to city water at no more that 30lbs pressure. Male sure water heater is drained and bypassed.
Fire up the compressor.
Wait until water stops blowing out out 1st faucet, then open another and close 1st. Follow that procedure going around and doing all faucets including the shower hose if you have one and outside shower. Do the two low point drains last.
After pumping in the antifreeze and you know it flowed to all areas, make sure you depress the spring loaded back-check in city water connection, open all valves. Just unscrew the low point drain caps about 1/2 way.
Mr Havercamp is offline   Reply With Quote
Old 11-01-2015, 06:28 AM   #4
They will be underneath, two pieces of pex tube sticking down out of the floor somewhere, usually red and blue.
Old 11-01-2015, 07:04 AM   #5
PhoneDude 8289's Avatar
To answer your question the caps are "on" while blowing out the lines. Drain and bypass the water heater. After opening all faucets remove the caps to drain the lines, this will also drain about 3/4 of the water from your water filter. Replace the caps, close all the faucets and connect the air to the fresh water line. with 30 to 40 lbs of air pressure on the system open each faucet starting at the farthest end closing it when only air comes out. Do this to all the hot and cold water faucets in the RV. Don't forget the outside shower if you have one. Remove low water drain caps again to release any remaining water in the low lines. Remove filter housing, filter and the strainer bowl from the pump. Power or "bump" the pump a few times just to be sure there isn't water in it. Drain all tanks and add the pink stuff to the traps. Your done in about an hour.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 11-01-2015, 10:48 AM   #6
Summer2Go
Summer2Go's Avatar
But can you do this in colder climates, like NY, Northern NJ, and Penn, where it gets into the 'teens on a regular basis?
Summer2Go is offline   Reply With Quote
Old 11-01-2015, 02:29 PM   #7
I have read that some as far north as Canada use this method. If you feel better after blowing everything out send the pink stuff through the water system.
Joe & Beverly
2014 8289WS lifted
Old 11-01-2015, 02:33 PM   #8
bareftn's Avatar
I have been under my 23ss roo and being a clean underside I see no blue and red caps at all both inside or on the outside of the frame rails
Old 11-01-2015, 04:04 PM   #9
bareftn's Avatar
well I found the caps the sticker is near the tires on the left side and the caps are in the very rear corner on the left side behind the skirting that's curls. I was 6 feet away from where the sticker says low point drains
Old 11-01-2015, 05:23 PM   #10
Mine are directly behind the sticker, next to the skirting. Red and a blue tube with black tops. Look like big vertical straws! Top may be hard to get off the first time. Just winterized this afternoon. Moved her to the side lot and now begins the long wait for spring😟
syogerst is offline   Reply With Quote
winter, winterize
