Old 05-06-2016, 12:46 PM   #1
Filter Housing Shattered
This is my second year de-winterizing the Roo 233S. I was shocked when I opened the door to the filter housing only to find it had shattered and all the antifreeze drained out.
It was completely full when I shut it down. It was a much milder winter this year than last year. So I'm wondering what happened and how do I avoid this in the future.
I've just run to Camper's Inn and got a replacement housing and bracket. They advised that I swap out the bracket since the parts essentially "mould together" over time. Wasn't too bad of a fix. But I don't want to have to do it again.
Thoughts?
the8re is offline   Reply With Quote
Old 05-06-2016, 12:53 PM   #2
You might consider abandoning that filter canister setup and go with an external filter. One of the first things I did to my rig.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 05-06-2016, 12:58 PM   #3
Ford Idaho's Avatar
Remove it!
Connect the two lines together with a 1/2 PVC coupler.
https://www.google.com/url?sa=t&rct=...qbsFnkrByB6ICw
Or.
https://www.google.com/url?sa=t&rct=...y-ZvMrasPFTsEQ
Old 05-06-2016, 03:53 PM   #4
Old Eeyore's Avatar
We attended a seminar about winterizing late last year at our dealer. (They were serving a free lunch!)
Anyway the tech advised against leaving the filter housing full. He said there was a risk that the antifreeze could get 'slushy' and expand enough to damage the housing. I winterized our old 21SS 5 times and never had any problems so I discounted the tech's warning. But after seeing this I'm reconsidering. . .
I'm not a fan of the housing and proprietary filter that came with the 23IKSS so I'm also looking at removing it and going with an external filter setup.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 05-06-2016, 06:02 PM   #5
Mine split last year, dumping water all over the back end of my 1year old ikss. Removed it, joined the lines with a sharkbite connector, and never looked back. This forum is full of posts about the cannisters either unscrewing by themselves or splitting and shattering. Truly a POS component in a $20000+ camper. Disappointed in FR for continuing to use it.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 05-06-2016, 06:21 PM   #6
I kept the internal filter location but replaced it with a new residential model that uses standard filters. I also blow all the water out with air and only run a little antifreeze thru the pump until the filter housing is about half full.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 05-07-2016, 12:22 AM   #7
Originally Posted by Ford Idaho View Post
Remove it!
Or.
X2
I just replaced mine a couple days ago with the coupler and outside filter. 62 cents for the coupler at Home Depot. $17 for the filter with the short flexible hose attachment at Walmart (it was $40 at the stealership!!).
Name:	Filter removed.jpg
ID:	107123   Click image for larger version
Name:	Filter replacement coupling.jpg
2011 Traverse LT, 3.6L, FWD
Old 05-07-2016, 01:22 AM   #8
ramair's Avatar
I had one crack on our MH and was advised that the plastic container can get cold enough to crack, we full time and have a heater in the bay. I had a replacement so not a big deal but have not had any further issues. Could have been just a defective container.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 05-07-2016, 06:18 AM   #9
An external filter only works with city water. We camp at state parks and use the water tank so we need the internal filter. Just something to consider.
Les & Heidi Kramer
Cleveland, OH
Old 05-07-2016, 09:54 AM   #10
Old Eeyore's Avatar
A very valid point.
But, it's easy enough to fill the fresh water tank through the external filter. Instead of hooking the outlet side of filter to the city water inlet you put on a fill nozzle and stick into the fresh water fill. (Or whatever way you normally get water into the tank.)
It will take a little longer - depending on the flow rate of the filter you use but the water in the take will be filtered.
This assumes that you always filter water before it goes into the tank or you perform some kind of sanitizing between trips.
