Old 02-06-2016, 12:47 AM   #21
RooVader's Avatar
This is freaking cool.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 02-06-2016, 03:20 PM   #22
I love the fireplace! Where did you find the insert to fit in that space? We have the same camper and would love to do this. Especially for heating the front bunk area.
KB
rollingroo is offline   Reply With Quote
Old 02-06-2016, 06:20 PM   #23
When Mikewcrook posted his, he listed the model as a 18ef023gra. The '18' is the key because that's the biggest model that will fit in that space. The '023' is the model with the blue highlites in the flame. They have discontinued this model. I did find one in a pawn shop on line in MT! Of course, I live in NC. But I checked at a local pawn shop, and they had one in a cabinet!! Here's a few pictures I posted in another thread.Click image for larger version
Name:	ImageUploadedByForest River Forums1454804383.614151.jpg
ID:	99054Click image for larger version
Name:	ImageUploadedByForest River Forums1454804397.197144.jpg
Nccamper is offline   Reply With Quote
Old 02-06-2016, 10:48 PM   #24
Yes I got mine off of amazon 2 years ago but I don't think they carry it anymore. Do a Google search for the model number. Might get lucky.
Mikewcrook is offline   Reply With Quote
Old 02-07-2016, 12:08 PM   #25
Thank you for the information .
KB
Old 02-22-2016, 10:44 AM   #26
D_TWEEZY's Avatar
Nccamper and Mikewcrook I also just finished installing my fireplace insert last night! I still have trimming out left to do, and to find a proper grille cover to go over the top of the insert, along with the 3 inch plugs for the hole I now have from where I moved the battery disconnect switch. Just curious Nccamper, where did you find yours at? the 3 inch plugs?
Also, for those that are interested, I was able to purchase a 18" Spectra Fire Insert from Menards for under $150.00 new!! Below is the link to it. I have also included a pic that I took late last night. Sorry about how dark it turned out. I'll fix it today hopefully! I just wanted to update those that there is in fact a newer version that does work and it fits perfect! It has 5 different light settings as well as brightness and flame speed adjustments.
I was also very impressed with just how much heat this thing puts out. I live in Iowa, and it was 34 degrees inside the trailer when I started. I had it running for about 30 minutes once I installed it, and when I looked up and I saw it was almost 65 degrees inside the camper, I couldn't believe it!
http://www.menards.com/main/heating-...4421691943.htm
Name:	2016-02-21 17.05.14.jpg
D_TWEEZY is offline   Reply With Quote
Old 02-22-2016, 01:13 PM   #27
Looks good, D_TWEEZY!! I used 3" aluminum soffit vents from Lowe's. They came in a five pack, so I put one on each side ( why not?) Painted them satin black, along with the 16" soffit vent I used in front and all of the screws heads. I took one of the pieces that I cut to fit the fireplace in the opening and trimmed it down to make a cross member for the bottom of the 16" vent and the top of the trim molding to attached to. I used rubber cement on the trim molding just in case I ever have remove the insert to access the slide out controller. Post more pic when you finish!
Old 02-22-2016, 03:10 PM   #28
Perfect! Fantastic job D_TWEEZY! I did the same as Nccamper and used a soffit vent to cover the top gap. Great Mod!
Old 02-22-2016, 10:10 PM   #29
D_TWEEZY's Avatar
Here's an updated photo with the almost finished product. I just have to paint the screws tomorrow. Tomorrow's agenda, shelving in the closets and in the kitchen!
2005 Chevy Avalanche 1500 Z71
2014 Rockwood Roo 23IKSS
Mods So Far:
FIREPLACE!! Wire Shelving in Wardrobe and above counter. Honeywell Thermostat.
To Do: TOO MANY!!!
Old 02-23-2016, 07:08 AM   #30
Good job D-TWEEZY!!
