Old 06-11-2011, 06:02 PM   #11
myfirstroo21ss's Avatar
Originally Posted by mtnguy
Even though that is a fairly small trailer, a WDH with integrated sway control like the Reese Dual Cam, Equalizer (brand), or Blue Ox would probably be a better solution than a WDH with a friction sway control bar. 1 less thing to hook up, also.
Thanks. Any suggestions on where to buy?
myfirstroo21ss is offline   Reply With Quote
Old 06-11-2011, 06:45 PM   #12
bikendan's Avatar
Originally Posted by myfirstroo21ss View Post
I have a Reese break controller and the dealer wants to sell me a husky distribution hitch with single sway control. They want 375 plus installation. Should I opt for something different?
yea, i'd get your money back on the Reese BC and get a Prodigy. and don't get the cheap-end Husky with the vastly inferior friction bar sway control.
i'm a big fan of the Equalizer. no drilling needed and no chains.
the best place to get the Equalizer or Prodigy, is RVW. you can get free shipping too. cost will be a little more than that Husky but is a way better WDH.
Old 06-11-2011, 09:06 PM   #13
I was given the Reese brake controller free and was only used once before my buddy traded the truck. If it makes more sense to buy a new one I will. Is this the hitch you are speaking of? http://www.rvwholesalers.com/catalog...0-00-1000.html
Ron
Old 06-11-2011, 09:10 PM   #14
Ron
Here is the brake controller http://www.autozone.com/autozone/par...ntifier=898203
Old 06-11-2011, 10:00 PM   #15
bikendan's Avatar
yes, that's the Equalizer i have. not sure which size you should get, since i don't know the tongue weight of the 21SS.
that Reese BC is time-based, not a Proportional based BC, which means it's old technology that is inferior.
only the cheaper BC's are time-based.
you can give it a try, since it was free. you can always find a P2 Prodigy for under $99.
Old 06-11-2011, 10:21 PM   #16
Thanks I appreciate the advise. So there is no drilling required for the equalizer? Installation should be pretty simple. My dealer wanted to charge me two hours @ $115/hr to install theirs!
Old 06-12-2011, 05:52 AM   #17
Triguy's Avatar
There is no drilling required.
I'm not sure why it would take your dealer two hours to install. I installed mine along with a tech from my dealer in about 45 minutes. It was handy using their tools, though.
You will need the equipment to be able to torque at some fairly high ft/lbs. The recommendation on the 3/4" shank bolts is 320lbs.
The most important thing is to understand how a WDH works and how it should look when installed and the trailer loaded. There are a number of videos, including one from Progressive, showing how to install that will help you to determine if you want to do it yourself.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-12-2011, 09:36 AM   #18
bikendan's Avatar
Triguy, the dealer wants 2hrs. to install the Husky WDH, not the Equalizer WDH.
i believe the Husky requires drilling.
Old 06-12-2011, 10:00 AM   #19
Welcome and enjoy your New Camper.
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 06-12-2011, 01:07 PM   #20
Triguy's Avatar
Ah, that's right. I forgot its a Husky the dealer wants to install.
Scott
2012 Shamrock 233S
