Old 03-12-2014, 09:43 AM   #1
First mods on a new hybrid
April 4 is the big day. That day, the WDH will be installed while we perform the PDI on our new 233S. I also had the Power Jack installed.
Once we get it home, what are some of the first mods I should consider doing before our first trip? The last camper was a pop up trailer, so the hybrid world is completely new to me!
the8re is offline   Reply With Quote
Old 03-12-2014, 09:50 AM   #2
IMO none. Go camping with it first. Just a short weekend and start to get a feel for what you need.
We have 2 daughters and we ended up getting a spring rod for the area between the fridge and the bathroom on which we have a large curtain. Creates a little more privacy for us and keeps it darker for the girls.
We also added shelves to the pantry near the rear bunks but we did this with a material shelving set that velcros around the upper pole. Still allowed for larger storage underneath.
We added wire shelving into all the lower cabinets to allow use to increase our storage capacity.
Last thing we did, which we saw someone else with, was bought 2 small ottomans that we keep a bunch of stuff in. They also allow you to put your feet up while on the couch. Great little storage addition
You won't know what you need till after you use it and figure out what you really need.
Our next mod will be with the shower...need to find a way to actually make it convinient and usable (oh buy an actual shower curtain as the one FR provides isn't waterproof)
2013 F-150 XTR Ecoboost 4x4, 3.73 w/Equalizer
2014 Roo 233s
Nights camped 2014: 28
Nights camped 2013: 17
Shado is offline   Reply With Quote
Old 03-12-2014, 10:16 AM   #3
KMP44's Avatar
Good advice - there are lots of things you can do, but get a feel for which ones you really want.
For me the one must have was actually to modify my Coleman grill to work off the low pressure quick connect hose on the Roo. No more propane cylinders thanks to some advice found on frf
And not really what I would call a mod, but we quickly found we absolutely needed a portable tank to empty the grey tank. Fills up quick when you don't have sewer! Also got X-chocks for Christmas as the camper tends to shake quite a bit. Haven't been able to try yet though.
Solar panels & a hard wired inverter are the next project if winter ever ends - snowing again - weather man says 12 inches today
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 03-12-2014, 11:16 AM   #4
Congrats on your new new 233S! Couple things you might want to think about.
1. On your popup did you have tent end covers and do the Reflectix mod for the bed end window areas? We just retro fit them both from our popup to HTT. If you didn't the covers really help in keeping the tops clean and the Reflectix helps keep the heat/cool in.
2. Consider a surge protector. Progressive Industries is the brand of choice. Progressive Industries
3. Covers for your roof vents. Airxcel | Maxxair | Maxxair II
Old 03-12-2014, 12:05 PM   #5
Ws98ta's Avatar
How did you do that? I have been wanting to do that for a while now.
2014 roo 23ikss
2014 silverado 1500 4x4 z71
Ws98ta is offline   Reply With Quote
Old 03-12-2014, 12:26 PM   #6
KMP44's Avatar
Here is the thread that I found most helpful. The picture in post #12 shows you what to do. As long as your grill has the detachable regulator, it should work. Not sure if the newer Coleman's work like this.
Coleman XLE Grill to RV LP Quick Connect
After several false starts, this thread solved the issue. You can't run the low pressure feed on the camper through the grill's pressure regulator and get enough heat to actually cook anything. So you need to remove the grill's regulator but there isn't anything I know of to connect directly to the grill if the regulator is removed - the fitting that connects the regulator to grill burner is some type of custom fitting. But if you look closely at the regulator assembly, it is actually 3 pieces. You can unscrew the portion that connects to the grill from the actual pressure regulator. When you do this, be very careful - there is a spring and some small parts inside. They are very hard to find after you drop them Then its just a matter of connecting the 1/8" npt connection on the piece from the grill to the quick disconnect on the trailer. I bought a second regulator from an aftermarket parts place. That way I still have the original to use cyclinders when tailgating. And I added a 12 foot extension hose to keep the grill away from the camper. Seems we get an occasional bear looking for leftovers. Prefer not to hang the grill on the camper.
2017 F-250
Old 03-12-2014, 12:46 PM   #7
Triguy's Avatar
X3 on waiting until after your first trip to do most mods. A paper and pencil is good so you can list the things you need/want.
But, there are a few things that many people do if you really want to get to work.
Not mods, but good things to have right off the bat...
  • Surge protector as mentioned.
  • Buy a decent awning mat - one that allows rain and dirt to drop through.
  • Bring two door mats. A heavy duty one for the outside and lighter-weight one for the entryway - otherwise you will be sweeping constantly.
Some of the things that people seem to add sooner or later:
  • X-chocks to control trailer movement when set-up
  • Vent covers as mentioned so you don't need to worry about open vents in case it rains.
  • Oxygenics shower head
  • Good sewer hose like the Rhinoflex
  • Two stick on levels for the camper so you can better level it.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-12-2014, 12:53 PM   #8
bikendan's Avatar
#1 Hybrid mod is getting PUGs(Popup Gizmos)or the generic 5x7 solar blanket versions.
Reflectix in tent windows is probably the next most popular mod.
i installed a hard-wired 400w inverter for dry camping, along with a dual battery setup.
definite yes on the most popular and easiest RV mod, the Oxygenics shower head!
did the homemade tandem wheel chocks for about $12.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-13-2014, 11:52 AM   #9
hockeytownmom's Avatar
I am the only one who doesn't like the Oxygenics shower head?
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 03-13-2014, 12:25 PM   #10
Resident Masshole
force's Avatar
Welcome to the Roo family!
I tend to agree, go camping once or twice, then start to build your mod list out.
That said, my 23SS mod list is here if you'd like to them out
I have another one here regarding the popup gizmos a few folks have mentioned
And if/when you consider a camper cover, check my feedback on Adco covers here
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
hybrid, modifications
