Old 10-02-2013, 09:58 PM   #1
First winter storage question
I am going to be parking my 21dk outside at my father in laws this winter. My question is do I just park it on the grass or should I drive it onto treated lumber? I will be putting on tire covers to protect them.
winger53215 is offline   Reply With Quote
Old 10-03-2013, 02:42 AM   #2
Just a member
kandl's Avatar
Put it on some treated lumber and it should be level.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 10-03-2013, 04:02 AM   #3
Send a message via MSN to Monterra
Why should the lumber be treated?
Good judgement comes from experience........
Experience comes from bad judgement!!!!
'10 2304 Mini Lite
'14 Honda Ridgeline
Monterra is offline   Reply With Quote
Old 10-03-2013, 04:13 AM   #4
Just a member
kandl's Avatar
The OP specified treated lumber - I played along. Doesn't need to be treated although treated stuff could be reused whereas untreated can get kinda mushy sitting under the weight of a TT over the winter.
Old 10-03-2013, 06:21 AM   #5
Canadian Member
We store our Roo at my cousin's farm in a field behind the shed. I bought a bunch of 24" square patio slabs to put on the ground for the tires and the stabilizers.
Old 10-03-2013, 10:48 AM   #6
Triguy's Avatar
I store mine on some old reconstituted-stone pavers I had laying around. Anything that will get the tires off the ground will work.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-03-2013, 11:40 AM   #7
Mod free 5er
Don't know it to be fact, but have heard treated lumber and tires don't like each other and the tires end up being the losers. Why not just put patio blocks on top of the treated lumber and park on them?
Old 10-05-2013, 09:24 PM   #8
So I should store it with the stabilizers down?
Old 10-05-2013, 09:57 PM   #9
Mod free 5er
I would jack the axles up enough so with jack stands under the framework for the suspension, the wheels are not touching the ground so it takes all load off the torsion and then run the stabilizers down accordingly.
DO NOT JACK ON THE AXLES!
Jack between the axles on the framework
Old 10-05-2013, 10:11 PM   #10
Mod free 5er
From our experience with our racecar trailer, which also had torsion axles, they will take a "set" when stored very long. We discovered this about 3 yrs ago when we noticed the tire clearance was less than when parked after its trip from Anchorage, AK. Jacked the frame (structural I beam frame) up and let the suspension hang. Clearance was back to normal when we put new tires on it in Jun.
Was easy on this trailer with the structural I beam frame, we simply lowered the front as low as it would go, put jack stands right behind the rear wheels, raised the front until the front tires were off the ground and put another set of jack stands in front of the front tires and released the load on the tongue jack.
Old 10-28-2013, 05:42 AM   #11
We recently attended a weatherization seminar and one of the points covered was to park our trailer on lumber for the winter.
I am curious to know; is it the concern to have the tires off the cold/wet ground or rather to insure the trailer stays level?
I have a full concrete pad to park on so leveling will not be an issue.
TV- 2018 F150 Super Cab XLT
TT- MicroLite 23FB
Tent2TT is offline   Reply With Quote
Old 10-30-2013, 08:29 AM   #12
Canadian Member
You'll be fine on a concrete pad a long as it drains and there's no standing water around the tires. Even a well draining granular pad is fine. The key is to not have the tires in contact with the soil. If you can take weight off the tires that's great but not absolutely necessary.
Old 10-30-2013, 09:46 AM   #13
Taylorgso's Avatar
From Michelin's RV tire maintenance guide:
"Michelin recommends placing a barrier (cardboard, plastic or plywood) between the tire and the storage surface.
Some good information here: https://www.michelinb2b.com/wps/b2bc...s_Brochure.pdf
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 11-10-2013, 05:13 PM   #14
One more question.....we are going to pull the camper to Memphis over thanksgiving. There are a couple cold days planned......in the 20's at night but above freezing during the day. Should I winterize it? The dealer told us at a winterization seminar that we should only worry if it is going to be below freezing for a couple days at a time.
Old 11-10-2013, 05:49 PM   #15
Witch Doctor's Avatar
As long as you get above freezing in the day you will be fine. Just disconnect your water hose and put it away at night. use your water tank and pump at night...
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-10-2013, 07:39 PM   #16
Taylorgso's Avatar
If you have a pressure regulator, take it off too!
Greensboro, NC
Old 11-10-2013, 07:47 PM   #17
Ford Idaho's Avatar
I made two of these and then leveled them.
I then backed the trailer on to them.
One reason is to keep the trailer from sinking and to keep the tire off the ground/dirt.
Old 11-10-2013, 09:46 PM   #18
Taylorgso's Avatar
I recall reading somewhere (Michelin site I believe ?) that if parking on concrete you should place plastic or wood between the tire and the concrete. Apparently concrete will leech some of the oils from the tire and hasten degradation of the rubber. Doesn't seem to be a problem with automobiles because they are driven regularly, and don't have a lot of weight, but RVs sit with the same surface in contact with the concrete for months at a time.
Greensboro, NC
Old 11-10-2013, 10:13 PM   #19
I miss stated my question......I have it in storage till my Thanksgiving trip.....it is to get cold for one night in the 20's but during the days above freezing....high 30's low 40's.
Old 12-17-2013, 11:23 AM   #20
I've been reading this thread and was curious if anyone know about gravel? I park my Shamrock 21rs in a gravel driveway. Is this ok? this is our first winter with our TT and from reading the posts it sounds like the ground/soil/moisture will degrade the rubber on the tires quicker than normal. Also what is the purpose of making sure it's level when parked?? Thanks!!
davemoore99 is offline   Reply With Quote
expandable, hybrid, shamrock, storage, winter
