Old 07-26-2016, 11:24 AM   #11
Lonestar1836's Avatar
Get a plastic flower pot, a piece of PVC pipe with a diameter large enough to fit your flag pole, and some quik-set concrete. PVC pipe goes in the middle, fill the flower pot about 2/3 - 3/4 full, allow to dry. You now have a flag stand, 1 each. You can drill a hole through the PVC and flag pole, attach hitch pin for stability. Works well.
Lonestar1836 is offline   Reply With Quote
Old 10-26-2016, 01:26 PM   #12
I know this is an older thread, don't know if you ever came up with a solution but this is the one we used for the popup and the current Roo, I either put it in the front hitch if I have the cover on the bed and need the tailgate down or the rear hitch if the cover is off.
- 2017 Rockwood Roo 21DK
- 2002 Avalanche 2500 8.1L 4x4
HostileJava is offline   Reply With Quote
Old 10-27-2016, 08:03 PM   #13
flagpoles
I know this is an older thread, but I recently made flag poles out of Aluminum 3/4 inch conduit for my 19fd shamrock hybrid. I had 3/4 inch conduit cut to the length I wanted. I then attached the flags to the poles with "wire ties" (aka zip tipes). I drove concrete forming stakes into the ground for bases. The ID of the conduit fits perfectly over the forming stakes and voilla....cool flagpoles. I can send pics if you need them. you can also store them inside the camper or in the compartment which houses the water pump without issue, ( I had mine cut to the length to fit in there).
bkc19922 is offline   Reply With Quote
