Old 06-20-2016, 05:42 AM   #1
dawg82's Avatar
Floor wet
We are camping at Ocean Lakes in Myrtle Beach. Woke up this morning to the floor soaked by the slide out at the front bed. What could be causing this. Any help would be appreciated. We have a 2011 21ss by the way
dawg82 is offline   Reply With Quote
Old 06-20-2016, 06:02 AM   #2
nomad297's Avatar
If it didn't rain, condensation from your air conditioner is getting in somewhere. Possibly at a slide seal.
Bruce
Old 06-20-2016, 06:03 AM   #3
A/C condensate? Has it Rained? Is your Dog House broke? Lots of ways! Youroo!!
Old 06-20-2016, 06:07 AM   #4
lgray's Avatar
Big swing in Temp's here is SC, add to that coastal humidity, likely condensation.
lgray is offline   Reply With Quote
Old 06-20-2016, 07:43 AM   #5
RooVader's Avatar
Leaking water filter?
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 06-20-2016, 08:14 AM   #6
dawg82's Avatar
There was a small steady drip coming from a line going to pump under front bed. Don't know why water would be there because I've never used fresh water tank. I capped it off and no more water. Still trying to figure out AC leaking around vent.
Old 06-20-2016, 08:19 AM   #7
SeaDog's Avatar
When you hook up to city water the line going to your pump is pressurized a check valve keeps the water from gong to your FW tank. If its condensation from the AC then you have a seal leaking on the slide I would suspect. keep us posted
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-20-2016, 08:22 AM   #8
Even if hooked to city water there is water present at the water pump.
The pump has a check valve built it to keep the city water from back-flowing into the fresh tank.
You didn't mention which side of the pump the leak occurred (suction/pressure) but just because you didn't use the pump, don't be alarmed to find water pressure on the discharge side of the pump when hooked to city water.
If the leak was on the suction side it's possible the check valve may be partially stuck open. Or, if you have an antifreeze port, possibly the valve for that was turned incorrectly.
Without knowing exactly what line you 'capped' or some pictures to better explain what you did to correct, we are only guessing to answer your question.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-20-2016, 08:42 AM   #9
shughey00's Avatar
I have noticed ( AC leaks) that when I have seen condesation leaks it always happens when...it is very humid...but the night temps are not very hot...by this I mean maybe in the 70's or so....AND I have put the AC fan on low.
When it is boiling hot at night we all probably have the fan on high...all vents are open ( if it is a ducted system) and no issues.
So just curious if you put it on low fan...which to me always caused condensation AND if the night temps were medium that combo has caused condensation. Once so bad I had puddles under each ceiling vent. Also cooler nights around 68 or so and low fan speed etc and you will get the AC compressor cycling as the system freezes up which also gets moisture going.
From then on fan on high..all vents wide open.
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
Old 06-20-2016, 09:52 AM   #10
dawg82's Avatar
Thanks guys the leak under the bed at the pump was because the valve was turned the wrong way. It was for the antifreeze port. As for the AC I'm going to try something different to see if the condensation issue is resolved
