Old 05-28-2013, 09:40 PM   #1
Wally Roo
phygenius's Avatar
FLushing the plumbing
I winterized the plumbing of our Roo 21SS using the 50 below non-toxic antifreeze. Now I wondering what is the best way to flush the system of that stuff?
_______________________________
2009 Rockwood Roo 21SS
2012 Nissan Frontier
Rocky Mountain National Park
phygenius is offline   Reply With Quote
Old 05-28-2013, 09:59 PM   #2
wyo700's Avatar
Hook a hose to the city water connection and open all the faucets, shower and toilet until it is no longer pink.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 05-28-2013, 10:05 PM   #3
Don't forget to triple rinse the water tank if you put the pink there. If you have any pink in the water heater make sure you really rinse it as well. They do not flush well if not fully rinsed.
Timtation is offline   Reply With Quote
Old 05-29-2013, 06:44 AM   #4
TURBS's Avatar
You need to sanitize system before use.
To sanitize:
Fill fresh water tank and then flush all lines till water runs clean.
Showers.
Taps.
Toilet.
Install 1/4 of bleach per 15 gallons of water in fw tank.
Flush all lines again till bleach can be smelled.
Let sit overnight.
Drain fresh water tank and refill with fresh water.
Flush all lines , taps , toilet and showers.
Un- bypass water heater, open ppressure relief valve and fill till air and water expells.
Remove water filter canister and install new filter"if applicable"
Remove water pump screen and clean "if applicable".
Old 05-29-2013, 07:16 AM   #5
TURBS's Avatar
Filters
Strainer
Old 05-29-2013, 07:18 AM   #6
TURBS's Avatar
Water filter canister
Summer position for wh
Old 05-29-2013, 07:19 AM   #7
TURBS's Avatar
Check anode rod
Pressure relief valve
