Old 06-06-2015, 07:10 AM   #11
Wolverine 1945's Avatar
Happened to us a couple times with our Flagstaff,,, it was around the Sky Light !!!
I hate Sky Lights,,, used to work on Manufactured homes,,, Sky Light are nothing but trouble !!! Make sure you check that roof at least once a year,,, twice would be better !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-08-2015, 09:03 AM   #12
I had the same issue and it was a leaking skylight. Hope this helps
tbrew100 is offline   Reply With Quote
Old 06-09-2015, 06:55 AM   #13
Roof leaks can be a bitch to find,,, like in a home the leak can be several feet away from where it shows up inside,,, I have seen where water can run several feet down a joice before it falls off !!! I have also seen where I though the SkyLight was leaking,,, and found it to be some thing else !!! Got to check it all,,, sometimes it is a very small opening !!! GOOD LUCK !!!
Old 06-09-2015, 11:02 AM   #14
This thread title made me laugh when I first read it.
I was thinking to myself "You found water in your shower? No kidding? Isn't that like finding sand in the desert?"
Iwritecode is offline   Reply With Quote
Old 06-09-2015, 05:24 PM   #15
Thanks all!! Happened again after a heavy rain. We think it is the skylight. Husband looking into repairing it.
raedale is offline   Reply With Quote
Old 06-10-2015, 06:43 AM   #16
Tell him to be sure he used the right sealer !!! And check everything !!!
Good Luck
show, shower, water
