Old 06-04-2015, 05:14 PM   #1
Found water in shower
Hi! New owner here. Our RV has been parked in our driveway next to the house for 3 weeks. I went in today and there was a little bit of brownish water in the bottom of shower. There is a skylight above shower and a vent in bathroom that was open all the way but it has a cover. We had a couple days of heavy rain last week. Also, the shower nozzle was hanging down as opposed to up on the holder. Where do u think the water came from?
raedale is offline   Reply With Quote
Old 06-04-2015, 05:22 PM   #2
ColoradoRick's Avatar
I would guess it came out of the shower nozzle hose but feel up all around the edges of the ceiling around the vent to see if you find any wetness.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-04-2015, 05:35 PM   #3
The mice were dirty
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-04-2015, 05:35 PM   #4
Flybob's Avatar
Could it be winterizing antifreeze (Pink) that ran out of the shower head when is fell down. If shower not used since winterized it could be that.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-04-2015, 09:33 PM   #5
Thanks all! Still not definite where it came from. We shall see what happens. I replied to all separately.
Old 06-05-2015, 04:50 AM   #6
Since it was brown and over the shower I would check the skylight. Take the trim ring down and check the wood/ceiling material for wetness/warping/discoloration.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 06-05-2015, 09:31 AM   #7
Water in the bottom of the shower usually means that your gray tank is full.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 06-05-2015, 09:39 AM   #8
If the rain hits the louvered side of my vent cover and the other cover is open I can get rain coming in. i would check the skylight also. On mine with large temperature swings like you get in the spring I was getting condensation on the outer dome and it was dripping down into the shower. I added some weather stripping to the inner dome and this helps allot.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-05-2015, 02:12 PM   #9
realebill's Avatar
Had the same thing happened to mine brown water in the tub. took the trim off on the skylight and saw that the Foam was discolored and damp. went up on the roof clean the caulking and put Eterna bond tape on it and ended the problem.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 06-05-2015, 02:29 PM   #10
Cyber Phrenologist
Radio's Avatar
We found "brown water" spattered in the shower. Skylight dome was cracked and leaking. Replaced the outer dome with a new "smoked" dome.
You definitely have a crack or other issue with the shower dome.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
show, shower, water
