Old 07-19-2012, 02:43 PM   #1
Freezer running on Gas
Does anyone have issues with their freezer while running on gas for extended periods?? The freezer in our Roo 233s doesn't seem to keep frozen stuff... frozen. After a 3 day trip the bread was soft some meat was soft etc...
It seems to work fine when plugged into power....
200smk is offline   Reply With Quote
Old 07-19-2012, 02:51 PM   #2
Are you sure the propane portion is working? Should work better on propane.
Old 07-19-2012, 02:54 PM   #3
TURBS's Avatar
Mine seems to work better on gas
B.o.n
Is your temp probe placed near the top of fins?
And not just the plastic slider either some times the probe slides down into plastic slider.
I took mine out and put it towards top of slider than re installed.
Ron
Old 07-19-2012, 02:54 PM   #4
Yep....propane works and is flowing fine. The fridge seems to work great on propane, kept the beer cold for that whole trip. Just seems like the freezer can't keep up for that length of time.
Old 07-19-2012, 03:00 PM   #5
f1100turbo is correct, make sure the sensor is at the slide to the top of the fins.
Old 07-19-2012, 03:02 PM   #6
Its not froze up is it?
SALTY is offline   Reply With Quote
Old 07-19-2012, 03:07 PM   #7
Salty...Its not froze up....
Dunn & F1100.....I'll check the sensor on the slider in the fridge....
Thanks for the help on this....!
Old 07-19-2012, 03:10 PM   #8
Never heard of a refrigerator freezing up, but we live and learn. What goes wrong to cause it freeze up?
Old 07-19-2012, 03:11 PM   #9
Terier's Avatar
I have to ask - Any chance that the door isn't shut completely?
There's been a few times my door looked closed but wasn't. It wasn't noticeable until pushing on the handle to check. Important clue was that some items on the door side were semi thrawed while the other side were frozen.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 07-19-2012, 03:14 PM   #10
The door is closed until it clicks for sure......I cannot verify if the seals are fully sealed at that time.....will double check that too.
Thanks.
Old 07-19-2012, 03:40 PM   #11
TURBS's Avatar
Thanks.
If door is secure when u shut it you should hear it draw a vacuum and see it draw tight.
