Old 04-28-2014, 08:27 AM   #11
mlong's Avatar
A tank with water in it would have the weight evenly distributed across the bottom. You would need a considerable amount of water in a concentrated area to apply the amount of force needed to make it belly like that. Maybe some heat radiating off of really hot pavement could have caused weakness to the tank. causing it to belly. It looks to me that the low point of the tank is there and that belly is made by design.
However, it is anybody's guess with the limited view of the tank.
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 04-28-2014, 08:37 AM   #12
AquaMan's Avatar
40 gallons of water @ 8lbs/gallon = 320lbs. That's considerable weight, and the bottom middle of the tank IS the weakest point.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-28-2014, 08:44 AM   #13
mlong's Avatar
That weight is distributed across the entire bottom of the tank. I could see your point if the entire bracket pulled out of the frame but it is at a specific point. Even at 1/2 full or 1/4 full the water is still evenly distributed. I think other forces may have caused this, maybe not. I'm just guessing.
Old 04-28-2014, 08:46 AM   #14
Brother Les's Avatar
If you look at the picture again, the side to side, frame to frame bar is bent. There is a bar going from front to back in the middle of the Fresh water tank. the full weight of a full tank was pressing on the tank from the middle of the tank. The side to side bar gave way. The side to side bars need to have twice the bulk strength (the one visible and the one to the front) and there needs to be a couple more front to back bar supports UNDER the water tank. Many campers really don't realize how close they are to losing their water tanks and blissfully go down the road at 65mph with a full load of water.
Brother Les
Old 04-28-2014, 08:53 AM   #15
AquaMan's Avatar
The middle of that tank will bounce like a trampoline. It's that force, that will bend the cross member
Old 04-28-2014, 08:54 AM   #16
mlong's Avatar
I'm not trying to say any of our suggestions are wrong. I'm just giving my opinion, which happens to be different than yours. We can "discuss" this back and forth defending our opinions but, only the original poster can confirm the true cause.
Hope they get an answer and a resolution so they can continue camping & not have a disaster on the road.
Old 04-28-2014, 08:55 AM   #17
Originally Posted by AquaMan View Post
To me, it still appears that the center of the tank is bellied down. The weight of that tank bouncing would almost definitely bend a 6' piece of bent angled steel.
Agree 100%! Youroo!!
Old 04-28-2014, 09:14 PM   #18
Dodge Guy's Avatar
Terrible! and did they really run the LP line under the reinforcement like that?!!!!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-29-2014, 07:07 AM   #19
Jimandchris's Avatar
Are you missing a front to back support? I just crawled under our 23SS yesterday to install a ball valve on the drain and noticed we have two front to back supports under the center of the tank. Hope they get it resolved for you!
Sent from my SAMSUNG-SM-T217A using Forest River Forums mobile app
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 04-29-2014, 07:29 AM   #20
AquaMan's Avatar
Wow! I didn't catch that first time through. Good call!
