Old 08-12-2014, 07:11 PM   #1
BMFLYFISH's Avatar
Fridge confusion
The camper ( 2015 2IKSS)
is in the driveway connected to shore power. The plug that the camper is plugged up to is controlled by switch on the inside. Wife turned the switch that controls plug off. I have the fridge on gas mode only and the and the fridge in the on mode (not auto). I was thinking the fridge would stay on and keep cooling with the gas on but it did not stay cool. Is something wrong with the fridge or did this happen because I did not have the auto switch turned on?
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
BMFLYFISH is offline   Reply With Quote
Old 08-12-2014, 07:14 PM   #2
Platokidd's Avatar
How is the battery? Even tho you are on LP you still need 12 volt battery power.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 08-12-2014, 07:39 PM   #3
Jimandchris's Avatar
In gas mode you still need 12 vdc so your battery disconnect switch should be pulled out (on).
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-12-2014, 08:15 PM   #4
BMFLYFISH's Avatar
The battery disconnect was turned on (pushed in). My pup fridge could only run on gas because would draw to many amps(?) off the battery. How long would the fridge run on the gas mode assuming the battery is fully charged?
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
Old 08-12-2014, 08:28 PM   #5
fonzie's Avatar
Normally push/pull type battery disconnect installed in RV's works as follow: push in battery disconnected, pulled out battery connected.
Fonzie
Old 08-12-2014, 08:39 PM   #6
indybp57's Avatar
Originally Posted by BMFLYFISH View Post
The battery disconnect was turned on (pushed in). My pup fridge could only run on gas because would draw to many amps(?) off the battery. How long would thefridge run on the gas mode assuming the battery is fully charged?
Our Roo disconnect is as Fonzie stated: push to disconnect. Is the power indicator on the fridge control panel lit? Does your light come on when opening the door? If not then you have no 12vdc. We have dry camped up to 4 days on the standard battery running the fridge on propane before we had to recharge. Of course we were very conservative with everything that draws off the battery. Also if there is a lot of air in the gas line it can take awhile for all that to get purged out before the burner will ignite. You will hear a snapping noise as it tries to ignite. I sometimes light a burner on the stove just to get all the air purged out.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 08-13-2014, 07:47 AM   #7
The only power the fridge should be drawing is for the gas solenoid to open and close it to cool the fridge. The only other possible power draw besides the light (which is only on when the door is open) is if you have a fan in the exhaust for the fridge. My 2015 23SS does not have a fan. You should be able to run off battery and gas for the fridge for at least 4 days without using anything else. And as others have mentioned the disconnect switch should be in the out (pulled) position for the battery to provide 12vdc. The fridge in your trailer is not like the pop up. Your pop up fridge could run off gas/elec or 12vdc (which drained the battery quickly). Your new trailer uses only minimal 12vdc for the fridge and the primary cooling is the gas. If in auto when plugged into power the fridge will switch from gas to electric or vice versa when you lose power.
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 08-13-2014, 08:21 AM   #8
cogito ergo moo
Cowracer's Avatar
Did you purge the line? I had to purge the crap out of my line before my fridge would finally light on the propane.
Can you hear the ignitor? You should hear a click-click-click of the ignitor when it tries to light. Listen from the outside.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 08-13-2014, 08:27 AM   #9
TURBS's Avatar
Originally Posted by cowracer View Post
did you purge the line? I had to purge the crap out of my line before my fridge would finally light on the propane.
Tim
x2
turbs
"sabre owners united"
Old 08-13-2014, 11:32 AM   #10
BMFLYFISH's Avatar
First of all... THANKS!!! The fridge in my old pup either operated on gas or ac current. You did not have to worry about having a 12 volt supply when it was in gas mode. I was still under that mindset. Lesson Learned! I have been letting my 3 year old push every button that she wants to push under my supervision so she will not have any curiosities about what they do. The only switch I have not let her push is the battery disconnect. She may have snuck one past me or it could have been that way since it left the dealer, but the battery disconnect switch was pushed in (off position). The fridge when I first plug it did everything that it supposed to have done. I was surprised that the temp for the freezer had dropped well below freezing and fridge had dropped below 40 degrees in roughly 5 hours. I was thinking that it would take at least 8 hours to get to operating temperatures.
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
fridge
