Old 05-16-2016, 11:27 AM   #1
Fridge door opens during travel
After finding food on the floor and blaming the kids for leaving the door open, we've realized it's opening by itself going down the road. Oops! We have a 2017 23WS. I'm not sure what the fridge brand is. Anyone know of a solution? It doesnt seem to be adjustable, and the I'm not sure about the effectiveness or compatibility of the options on Amazon. Thanks!
joinco70 is offline   Reply With Quote
Old 05-16-2016, 12:10 PM   #2
Head Rambler
It's most likely a Dometic. They have a type of catch built into the handle that catches on a small plastic insert in the door frame when closed. If the catch part of the handle is bent or broken it won't hold the door closed, and also if the insert in the door frame gets rounded off or is missing, it won't hold the door closed.
The little insert got rounded off on the fridge in our last unit so we just used a bungee cord to hold the door closed.
The fridge comes with an insert in both sides, so if yours is rounded off or missing, and you're up for a challenge, you can remove it from the hinge side and install it on the handle side.
Gotta go campin!
Old 05-16-2016, 12:52 PM   #3
I know that my fridge and freezer door both do not latch if you just close the door. They have to be really pushed closed to latch fully. Same goes with the microwave. My son opened the microwave once, and closed it at the bottom of the door. The top latch didn't catch, and around a corner the glass tray came flying out, and shattered everywhere. I blamed him for leaving it open, and he swore he closed it. A couple weeks later I accidentally reproduced it, and had to apologize for misplaced blame. Now we all know.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-16-2016, 01:17 PM   #4
X2. DW's always complaining I didn't close the door hard enough.
2011 Traverse LT, 3.6L, FWD
Old 05-17-2016, 11:23 AM   #5
X3
We figured that out on our 2nd trip with a new trailer last year. Give the door a firm push after closing. You should hear a "click" indicating that it locked. To confirm, grab the door edge and try to pull it open. It shouldn't open unless you use the handle, which unlatches the door. This is the same for both the fridge and the freezer.
ebcobra93 is offline   Reply With Quote
Old 05-17-2016, 02:04 PM   #6
Thanks everone! I'll give the door a good push and see if that helps.
Old 05-18-2016, 06:51 AM   #7
For piece of mind, you could get a door safety latch from the baby proofing section in a baby store. I have one on our freezer bc the kids slam the home fridge and the freezer will come open.
tuckerfamily is offline   Reply With Quote
Old 05-18-2016, 06:54 AM   #8
Scottie King Size Adjustable Children Safety Locks, Baby Latches To Refrigerator, Drawer, Cabinet, Dishwasher, Toilet Seat, Easiest Installation, Brown Color https://www.amazon.com/dp/B01D9SPZ3G..._OFfpxbB5NHRWP
Old 05-18-2016, 06:59 AM   #9
Wolverine 1945's Avatar
Originally Posted by ebcobra93 View Post
X3
Right On !!! You must hear the click,,, if your doors are right !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-18-2016, 09:20 AM   #10
Tom48's Avatar
On our old trailer the six cu ft domestic was always stuffed full. We found that some of our plastic storage containers were too wide for the lower shelf, by just a fraction of an inch. That put pressure on the lower end of the door and not only made it hard to fully latch the door, but kept the bottom edge of the door from a tight seal. Made it hard some trips to keep the frig cold, and eventually broke the door latch about the time we figured out the problem. Surprisingly small pressure at bottom of door kept it from closing tightly at the bottom edge.
Tom48 is offline   Reply With Quote
door, fridge, travel
