Old 07-13-2014, 10:12 AM   #11
Do you have a multimeter to check the voltages? You need to check the voltage at the wire from the circuit board and then go to the back of the fridge, you can get to the back of the fridge by removing the bottom cover on the outside of the trailer. If you have voltage at the circuit board but not at the fridge then you need to follow the wire from the circuit board and find out were the voltage stops. Some times they will but inline fuses behind panels. Is there one or two wires going to the fridge furnace at the circuit board? If only one there must be a junction point somewhere
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-13-2014, 10:10 PM   #12
rbq
Remove the outside fridge vent cover. Look to the right of the compartment and you will see the stack that vents out the roof. On this stack there are 2 wires connected. They may both be red as in this picture. In between those wires is a resetable circuit breaker. Put your finger between the wires & push this breaker to reset. Go inside & check to see if the fridge lights are on. There is a good chance that this is the easiest fix you will have to get your fridge working. I speak from experience as I had a similar situation & when I called the dealer they directed me to call an RV repair place. Since I was out in the boonies the guy had me do this & the fridge worked fine since then. This breaker protects the fridge from overheating from being out of level for too long of time or for other reasons. Good luck. Let us know if this works.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 07-14-2014, 07:36 AM   #13
kfree1711's Avatar
Awesome! Will check today. Thanks!
2015 Rockwood Roo 23IKSS
2009 Ford F150 Platinum
Nights Camped - 21
Camped Every weekend in July :=)
kfree1711 is offline   Reply With Quote
Old 07-14-2014, 08:10 AM   #14
Also, there are two fuses in the outside fridge compartment on the circuit board, one for 12vdc and one for 120vac. If it goes the fridge will do what you are saying. It is interesting that you found a fuse inside for the fridge/furnace, I do not have that for my 23SS. My fridge is not fused on the inside.
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 07-14-2014, 08:26 AM   #15
jonrjen's Avatar
We had the same problem on our Wildcat 5th wheel. It was recommended to look for a resettable breaker on the distribution panel also. Once I put on my glasses and held a flashlight just right I could see that little bitty reset button.
Didn't help that it was dark in the compartment, the breaker was black as is the reset button.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 07-14-2014, 12:50 PM   #16
Thanks for the location of yet ANOTHER hidden/unknown switch/fuse on my camper!! This place is a wealth on info.
Thanks Again!!
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 07-14-2014, 04:47 PM   #17
kpm
kpm's Avatar
Yes. this place is great!!!!
kpm is offline   Reply With Quote
Old 07-14-2014, 05:48 PM   #18
DK-in-SC's Avatar
Thanks Again!!
+1 to that. The more I hang around here the more I'm starting to realize that only 20% of the fuses are actually in the fuse box. Silly me.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 07-14-2014, 07:19 PM   #19
clancythecamper's Avatar
I must admit, the issues with the fridge seem to be the most frustrating ~ ya gotta keep your food and beverages nice and cold! ~ funny story ~ we had a 5er that the fridge needed "jostling" from time to time. No problem as we would "jostle" it everytime we went somewhere, except the year my DD won 1 month at a nice RV park So after a week or two we needed to "jostle" it but didn't want to hook up and move it so I sent DD, DS, and DH out to jump up and down on the bumper (after lifting the jacks) yes, it worked and the neighbors thought we were crazy ~ still laugh at the memory of their expressions!
clancythecamper is offline   Reply With Quote
Old 07-15-2014, 09:32 PM   #20
I had a similar problem on our 2014 ROo 23IKSS removed cabinet drawers and checked clear connector were fridge was plugged into had a bad connection inside clear connector repaired it and took care of the problem!
Brunnerb1 is offline   Reply With Quote
fridge
