Old 11-08-2010, 10:01 PM   #1
Cool Front Bunk Door Repair
Well its a perfectly dry week here in western N.C. so I decided now is the time to remove the front bunk door on my '99 Shamrock 21 to "attempt" some repair. Progress is good so far...done some scraping/sanding and figuring out how the door is made. My question for the forum is--how do these doors hold two people up?? I mean really this is two luan boards sandwiched around styro and a small frame with one center bar. I thought the point where the door poles attach were supported by a cross member but no they aren't! Past water damage has made the portion closest to the hinge essentially disentegrated so I plan to put a new board on the interior. Second question--would it be appropriate to put hardboard material here instead of luan. They are very close to the same thickness. I have a piece on my workbench as a protector and the stuff is tough. The nice thing too is I can get it in the "dry erase" type on one side and that is enough to make the interior visually pleasing because it is nice and shiny white. My third question is on the outside. I have considered calling FR and getting a price on the exterior panel. Since I'm new here I don't know how good of an idea calling the factory for anything like this is.
LuckyShamrock is offline   Reply With Quote
Old 11-09-2010, 07:24 AM   #2
give it a try, I would think you could just order a replacement door, but I bet you can repair it better.
What is Luan?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-09-2010, 06:49 PM   #3
yvesm's Avatar
You can get anything from the Forest River parts department, they are helpful.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 11-09-2010, 07:35 PM   #4
RV Newbie
buzzards27's Avatar
Originally Posted by threegr8katz View Post
What is Luan?
Closely related to mahogany but not a true mahogany. It is also called "Philippine mahogany" (White Lauan from Shorea almon or Red Lauan from Shorea negrosensis), usually used in thin plywood sheets, most commonly 1/4" that is used as an underlayment for floor coverings. Tight grain.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 11-09-2010, 08:12 PM   #5
Another question....I am thinking about having a couple cross members welded into the door frame for more sturdiness. Anybody disagree?
Old 11-09-2010, 08:15 PM   #6
a new door with installation by the local dealer was going to be over $1000. I am fast learning that campers are a handyman's common task so I am doing the work myself for hopefully under $20.
I need suggestions on glue material....would a contact cement rolled onto luan be ideal or would something out of a caulk gun or gorilla glue be better or nearly the same?
I might be giving FR a call tommorrow about the exterior panel only...will post what I find out.
Old 11-09-2010, 10:02 PM   #7
RV Newbie
buzzards27's Avatar
I believe you need a glue specially made to bond to styro. Some glue will react with the foam to the point of melting it. I know there are things off the shelf that load in a caulking gun. try the big box stores.
Old 11-11-2010, 08:03 PM   #8
bunk door update
$20 !! what was I thinking??? Oh well, I have bought some materials. They include contact cement, a roller for that, tube of foam adhesive, a piece of aluminum for extra bracing, two pieces of lauan, one blue board (foam insulation), a scraping blade for my oscillating tool, and some epoxy glue to fix a crack. So I'm in for nearly $100 now but its going well so far!
Old 11-12-2010, 07:48 AM   #9
RV Newbie
buzzards27's Avatar
Good luck shamrock, do take pictures.
Old 11-21-2010, 06:50 PM   #10
for those interested in pics of the finished door, I started a new thread under the general discussion titled Bunk Door Repair Photojournal
I'm pleased with the outcome of the door.
expandable, hybrid, shamrock
