Old 01-18-2019, 09:33 AM   #21
Professional Curmudgeon
wrvond's Avatar
As pointed out, it's a simple docking light with a switch located on the bezel. Exposure to road grime, etc. causes corrosion in the switch and the bulb contacts. Clean and apply dielectric grease. The bulb is an 1156.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 01-22-2019, 12:08 AM   #22
Found the switch and light works fine. Thanks for everyone's help.
mitchlandry is offline   Reply With Quote
Old 01-22-2019, 12:19 AM   #23
bikendan's Avatar
Since different switches were mentioned, which one was it?
Old 01-22-2019, 12:22 AM   #24
Sorry, it was a light mounted switch on the bottom of the light housing. Easy to find if you just feel across the bottom of the housing.
Old 01-22-2019, 09:35 PM   #25
ycj
Thanks, I'll check it out.
Yours should have a rocker switch. My switch went bad after two years and I have to slowly roll it to find that "just right" position to get it to work.
If you look inside, you may find some rust on the contacts.
If you still run into issues, the lights are fairly inexpensive. I think this is the correct one.
https://www.amazon.com/dp/B010PIMWT8..._Zi9rCbYH615SD
ycj is offline   Reply With Quote
Old 01-22-2019, 10:10 PM   #26
bikendan's Avatar
The OP already found it back in post #22.
Old 01-24-2019, 10:53 AM   #27
Chuck_S's Avatar
We must be getting cabin fever. Three pages of a thread on the light switch on the bottom of the front light.
-- Chuck
Chuck_S is offline   Reply With Quote
light
