Old 06-21-2014, 07:32 AM   #1
castlemusic's Avatar
Front trim replacement
So, I lost the passenger side trim on the way home from our last trip - see pic. It's my own fault, as I noticed it was cracked while camping, and made a mental note to reinforce when I got home. What I SHOULD have done was remove it before getting on the road! Lesson learned!
So, I called FR to get a replacement quote. It's part number 10-12346A, price $52.76 (!). Yikes - a lot for a piece of molded plastic. So, I've been considering another option - putting a 2' X 8' piece of diamond tread across the front, notching it around the tongue. (0.045" tk Natural Aluminum Diamond Plate) I'm not crazy about the diamond tread look, but don't want to have to keep replacing plastic pieces. Thoughts?
Name:	2014-06-20 07.50.23.jpg
The Castles
Brody, Jeanne & 6 great kids!
2011 Shamrock 233S
2005 Chevy Express 3500
castlemusic is offline   Reply With Quote
Old 06-21-2014, 08:05 AM   #2
MOD Guy's Avatar
It's not common to have this trim come off. Did something maybe hit it and cause damage? I would replace it, and reinforce the new part with some additional brackets and/or put spray form insulation on the back of it to make it more ridged.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 06-21-2014, 08:32 AM   #3
Replace it and cut a pc of alum tread plate to fit behind it as a reinforcement. It could be pop riveted along the bottom and top. That way if something hit it, it wouldn't be as susceptible to breaking.
Old 06-21-2014, 08:43 AM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
Replace it using anodized black aluminum tread plate and never worry about it again.
05CrewDually is offline   Reply With Quote
Old 06-28-2014, 05:33 AM   #5
So, I decided to bite the bullet and order the replacement part from FR. I also think I'll try MOD guy's spray foam suggestion. Thanks!
The Castles
2011 Shamrock 233S
Old 06-28-2014, 06:29 AM   #6
Strongly recommend an alum sheet reinforcement. Foam will not do much for strengthening a plastic panel unless it is backed with something to form a 3 pc sandwich.
Old 06-28-2014, 06:59 AM   #7
I'm hoping the foam will create a "sandwich" between the plastic trim and the frame crossmember, thus strengthening it for future hits of road debris. I'll post back pics when done.
The Castles
2011 Shamrock 233S
Old 06-28-2014, 07:19 AM   #8
How about using pt wood to fill the void?
replacement
