Old 04-27-2013, 04:21 PM   #1
Fuse box question
Hi all,
I'm a relatively new Roo 19 owner so still getting used to working out kinks. My stereo has stopped working (Concertone ZX75) and I've also noticed that the indicator light in the fusebox for the stereo is lit, but the 15A fuse is still intact. I checked the glass tube in-line fuse behind the stereo, and it's also still intact. Trying to track down the problem... any thoughts on this issue?
Thanks, Dennis
dmccunney is offline   Reply With Quote
Old 04-27-2013, 04:35 PM   #2
Moderators' Assistant
bikendan's Avatar
look for this, usually under the fridge:
i'm surprised that you weren't shown it during your PDI. but then, many dealerships don't do good PDI's anymore and rush new owners through them.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 04-27-2013, 09:04 PM   #3
The information sheet for the panel in our motorhome which looks similar to bikendan's photo says that the indicator light is on if the fuse is blown. Pull the fuse and check it for continuity, or swap it for a known good fuse. They can be blown on the end of the fusible link and the open spot can be hard to see.
Old 04-27-2013, 10:40 PM   #4
TURBS's Avatar
You beter get a cheap volt ohm meter and keep it in the camper as you'll need it.
Sometimes the fuses can "look" good when in fact they are not.
Switch the fuse with another in the panel and see what happens.
