Old 09-03-2015, 05:55 PM   #1
n4uaj's Avatar
Gas grill trouble
Y'all tell me a question? How come this silly gas grill that come with our 183 does this? I just didn't wanna fire up charcoals for my 2 hot dogs.
Name:   ImageUploadedByForest River Forums1441320930.896808.jpg
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
Old 09-03-2015, 05:57 PM   #2
Comes with what?.. sorry I'm confuzzled.. the knob on the side allows you to turn the gas on.. and regulate how much..
Roo Camper
Retired and loving every minute !
Roo Camper is offline   Reply With Quote
Old 09-03-2015, 06:04 PM   #3
n4uaj's Avatar
Fire comes out between the knob and the grill like something must be stopped up. Picture didn't do the flame justice 😀
Bill
2014 Shamrock 183
Old 09-03-2015, 06:08 PM   #4
Does the fire go across the bar inside?.. and it should burn more blue than yellow
Roo Camper
Old 09-03-2015, 06:17 PM   #5
VinceU's Avatar
Propane should inject into burner tube, mix with air then burn the entire length of burner. Tube alignment not correct now (tube too gar from burner) or gas cannot follow burner tube.
Old 09-03-2015, 06:45 PM   #6
wfmdfm's Avatar
Can you re post the picture? Is this a side Kick Grill? If so you may need to replace the control valve. The nozzle is attached to it and can snap off very clean where it enters the burner area. I have done this twice after dropping the grill with the hose still attached. I know you would think I would learn. I think this is what I used.
Amazon.com: Camco 57274 Control Valve with Quick Connect: Automotive
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 09-03-2015, 06:46 PM   #7
wfmdfm's Avatar
After seeing your picture I think it is the same issue I had.
2015 Toyota Tundra
gas
