Old 02-14-2013, 03:08 PM   #1
Rcandvicki's Avatar
Question Generators again please
I have a Troybilt 3550 Generator but it is 20 amp/4 prong on the generator,and on the TT i have a 30 amp 3 prong.Am i to assume that this generator cannot be used when boondocking?
Does the generator need to be a 30 Amp?
Your help would be appreciated.
2013 Shamrock 21ss.
Rcandvicki is offline   Reply With Quote
Old 02-14-2013, 03:11 PM   #2
TURBS's Avatar
2013 Shamrock 21ss.
If you want to run a/c and anything else yes you need 30 amp.
Search "normal appliance amp draws"
On here.
I posted a chart of amp draws.
A/c and converter take over 20 amps alone
Old 02-14-2013, 03:35 PM   #3
daydreaming about camping
jeeplj8's Avatar
you should have a regular 3 prong household outlet on your genny, you can use a 20-30 amp adapter just as you would plugging your TT into an outlet at home.
As turbs stated, you will not have enough to A/C and anything else, but should be able to run A/C by itself.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 02-14-2013, 04:08 PM   #4
TURBS's Avatar
X2
21ss hybrid, expandable, hybrid, shamrock, generator
