Old 04-20-2016, 05:28 PM   #1
Unhappy Genesis 2.0 no power
I am having a problem in that there is no power. I have checked the fuse and everything else in the trailer works. Any ideas on what could be wrong? The trailer is a 2014 roo 23ss. Thanks
Grant
hereIam is offline   Reply With Quote
Old 04-20-2016, 05:43 PM   #2
bikendan's Avatar
I think there's a fuse that you have to pull the Genesis out to get to.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-20-2016, 05:43 PM   #3
I was just looking at it again and I also have a wire tha has 2 wires in it that is coloured white and yellow that isn't connected. I tried to take the unit out but the cables on the side get stuck.
Old 04-21-2016, 06:34 AM   #4
Dave Lyon's Avatar
I believe you're right Dan. My buddy has same trailer and went through this a while ago.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-21-2016, 05:05 PM   #5
rsdata's Avatar
You don't get the unit to light up to show that it is getting power? I don't recall seeing a fuse behind the unit. Are you sure all of the fuses in the converter power box are good?
I don't have the exact same camper, but after you pry off with a small screwdriver the two long thin sides (top to bottom) and expose the three on each side screw holes, (I only had 3 screws in the 6 holes), the Genesis unit has to be able to slide straight out. There will be a little extra wire behind the unit allowing you to see what is behind the Genesis.
If yours is like everyone's you will not get stereo playback except from the outside speakers, unless you rewire it from the back. As I recall there is a wiring diagram on the back of the Genesis unit. My entire left (or right) channel was not even hooked up to inside speakers.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-21-2016, 06:20 PM   #6
Mrpsyko's Avatar
In line fuse
My Genisis 2 had a inline fuse behind the radio, had to pull radio to get to it.
Now it has no fuse behind radio.
Mrpsyko is offline   Reply With Quote
Old 04-21-2016, 07:07 PM   #7
Thanks now I have to figure out how to get in there. Seems silly to have a fuse you can't to without taking the trailer apart.
power
