Old 07-11-2016, 10:48 PM   #11
Old Eeyore's Avatar
We found that camping at higher elevations (between 8K & 10K) the water heater really struggled and the propane disappeared fast. That's when we switched to electric and we haven't gone back.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 07-11-2016, 11:53 PM   #12
Sky&Scuba
kendive's Avatar
I have been adding a water heater switch to all out our campers.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-17-2016, 12:20 PM   #13
Summer2Go
Summer2Go's Avatar
So what's the water heater switch on the inside panel? That's what I though I was using to turn the water heater on and off. But I may have only used propane.
Summer2Go is offline   Reply With Quote
Old 07-17-2016, 12:55 PM   #14
SeaDog's Avatar
If you rig is like mine that switch puts power to the propane side of the water heater, If I want to use elect or both I have to go outside and turn on the switch at the water heater. look on your unit for a small switch inside the water heater compartment
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 07-17-2016, 12:56 PM   #15
SeaDog's Avatar
that is a nice addition.
Retired Navy
2006 F350 6.0
AF&AM of Idaho
Old 07-17-2016, 04:30 PM   #16
Moderators' Assistant
bikendan's Avatar
Apparently your dealer failed to explain how the WH works, during your PDI.
All Roo/Shamrock hybrids have Suburban WHs.
The inside switch is propane only.
But you also have electric heat, which is accessed through the outside WH hatch. There's a black toggle switch in the WH.
NEVER turn it on until you're sure you have water in the WH.
Make sure you add it to your checklist.
What they are talking about is adding an inside switch for the electric side, so they don't have to go outside to turn it on or off.
You can use the WH breaker to do the same.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-17-2016, 09:30 PM   #17
Old Eeyore's Avatar
That's what we do as we always use electric for WH.
Part of the setup checklist.
- Water in the tank
- Bleed air out of the lines
- Flip the CB
Old 07-17-2016, 10:07 PM   #18
Mr Havercamp's Avatar
On our 2017 23WS we have a switch on the main control panel for water heater electric. No need to add a switch. The switch on the heater itself is there, but secondary. Turn it on at the beginning of the season when you dewinterize and fill the heater, and leave it on. Then you can control it with the inside switch. Evidently they did not have that setup in 2014?
2017 Roo 23WS
2015 GMC Sierra 2500HD
Mr Havercamp is offline   Reply With Quote
Old 07-17-2016, 10:27 PM   #19
bikendan's Avatar
I bet that's new for 2017.
Is it a Suburban or Atwood WH?
I knew Atwoods had an inside electric switch but Suburban didn't unless they've made some changes.
Old 07-17-2016, 11:26 PM   #20
n4uaj's Avatar
The biggest electrical problem I've had with our 183 is the outside outlet. We can't have a griddle plugged in there without popping the 15A breaker inside. Had it at the dealer while it was still under warranty and they claim it was fine. It's also on the same circuit as the outlet beside the stove as you come in. My only solution has been to run a drop cord from the power pedestal's 20 A outlet. I can then run the griddle, coffee maker, and toaster outside.
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
