Old 07-17-2016, 11:36 PM   #21
wmtire's Avatar
Originally Posted by bikendan View Post
I bet that's new for 2017.
Is it a Suburban or Atwood WH?
I knew Atwoods had an inside electric switch but Suburban didn't unless they've made some changes.
Dan, Suburban for years have had basically two combination propane/electric models of water heaters used in Forest River products. The SWDE model only has a electric switch on the outside to turn the element on/off.
The SWDEL model is very similar to the Atwood, and although it does still have the outside switch like the SWDE model, it also has an inside 12 volt switch that controls a relay to send power thru to the outside switch. With this model, you just leave the outside switch on, then use the inside switch to control the relay thus turning on/off the electric heating element.
It can get kinda confusing here in offering advice, without knowing exactly what brand and/or model the member has. Forest River uses the Atwood brand, as well as the Suburban brand, with the SWDE model and SWDEL model. We are actually seeing many more FR products coming out with the SWDEL model, as customers are wanting the inside switch.
Both Suburban models (SWDE and SWDEL) are explained in this link:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Wanna know how I plan on cutting carbs next year?
With a pizza slicer.
Old 07-18-2016, 12:21 AM   #22
Moderators' Assistant
bikendan's Avatar
Originally Posted by wmtire View Post
Dan, Suburban for years have had basically two models of water heaters used in Forest River products. The SWDE model only has a electric switch on the outside to turn the element on/off.
Well, they've never had the SWDEL in the Roo/Shamrock hybrids until apparently the 2017 models.
Haven't ever heard of any previous model years having them.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-18-2016, 08:23 AM   #23
SeaDog's Avatar
Originally Posted by n4uaj View Post
The biggest electrical problem I've had with our 183 is the outside outlet. We can't have a griddle plugged in there without popping the 15A breaker inside. Had it at the dealer while it was still under warranty and they claim it was fine. It's also on the same circuit as the outlet beside the stove as you come in. My only solution has been to run a drop cord from the power pedestal's 20 A outlet. I can then run the griddle, coffee maker, and toaster outside.
I solved that problem on my flagstaff by adding two circuits which was easy to do only had to pull on run of wire. Now the bath and outside plug our it own 15A. If you are interested send me a pm and I'll explain in detail.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-18-2016, 07:18 PM   #24
GalsofEscape's Avatar
Hey Dan - I think my 2016 Shamrock has the SWDEL water heater- at my PDI, I was told that there is rocker switch on the water tank that I had to flip first before I turned on the electric on the panel -
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
Traveled 19520 miles and 209 nights in 7 years and counting
GalsofEscape is offline   Reply With Quote
Old 07-18-2016, 09:25 PM   #25
bikendan's Avatar
No, apparently the SWDEL'S also has an additional electric switch, which is inside the RV,on a panel.
not just on the outside on the water heater.
You have the regular SWDE, like me.
Old 07-18-2016, 09:28 PM   #26
No, it has the switch on the panel inside.
Old 07-18-2016, 09:43 PM   #27
Mr Havercamp's Avatar
Sure does............ the 2016's I have seen have it, and I am fairly certain 2015 had it also.
Ours is a Suburban but I wish it was an Atwood with no anode rod.
2017 Roo 23WS
2015 GMC Sierra 2500HD
Mr Havercamp is offline   Reply With Quote
Old 07-18-2016, 10:46 PM   #28
Gals: If you have it, then you should have TWO switches inside - one for gas, one for electric - and one switch outside - for electric. Is that what you have?
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 07-18-2016, 10:49 PM   #29
Yep, I do. Two switches inside, one for gas and one for electric with another switch on the heater tank itself. It needs to be on to run on electric.
Old 07-19-2016, 08:05 AM   #30
wmtire's Avatar
Yep, three switches total (a 12 volt switch inside as well as a 120 volt switch outside for the electric element) along with a 12 volt switch inside for the propane/dsi.
That's a SWDEL model, just as you stated.
FYI, if you ever need the installation/operation guide for this particular model of Suburban, we added it's operating manual to the library awhile back.
http://www.forestriverforums.com/for...do=file&id=169
