Old 08-16-2014, 06:00 PM   #1
urocav2001's Avatar
Gfi outlet
Ok so my gfi outlet tripped today, I had all three heated mattresses plugged in and a radio controlled battery charger plugged in outside, nothing got wet, no fuses look blown or no breakers are tripped, I unplugged everything and it still won't reset... Any other suggestions?
urocav2001 is offline   Reply With Quote
Old 08-16-2014, 08:04 PM   #2
urocav2001's Avatar
Also noticed all of the gfi outlets don't work? I am assuming the gfi itself is bad. One outlet works near the converter box which is a non gfi outlet.
Old 08-16-2014, 08:10 PM   #3
Try turning each breaker fully off then back on. Sometimes that solves the problem.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-16-2014, 08:29 PM   #4
urocav2001's Avatar
Tried that no luck :/
Old 08-16-2014, 08:51 PM   #5
VinceU's Avatar
More than likely the GFI is defective. They are the most likely of all outlets to quit. The reg outlets downstream are regular outlets fed by the GFCI. Check before shopping, most RV use a shallow style box and outlet and standard shoreside units won't fit. Replacements are inexpensive.
VinceU is online now   Reply With Quote
Old 08-17-2014, 08:16 AM   #6
urocav2001's Avatar
Ok thanks
Old 08-17-2014, 10:21 AM   #7
urocav2001's Avatar
Yup bad gfi outlet, all fixed now
