Old 03-11-2015, 12:32 PM   #11
wana65stang
You can use a multi meter & they may make a plug in tester but I'm not sure. I like the convenience of the plug in style surge protectors for that very reason; just plug it in & it will tell you of any issues before you hook up everything else.
Papa GLS is offline   Reply With Quote
Old 03-11-2015, 12:39 PM   #12
Papa GLS I am looking for something I can carry in the cup holder to do a fast go/no go test before I unlock compartment and pull out my EMS -30
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-11-2015, 12:42 PM   #13
wana65stang
I know they make a simple plug in voltage tester, but not sure about reverse polarity & ground testers. If I find any I will let you know.
Old 03-11-2015, 12:43 PM   #14
B and B's Avatar
I use a slam in light tester on a 30 amp to 15 amp adapter
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-11-2015, 12:53 PM   #15
Originally Posted by wana65stang View Post
My EMS-PT-30 is great on testing but was wondering if there is a simple plug in tester that you can slam into 30 amp socket before pulling everything out to hook up?
Yes. Purchase an RV 30A male to 15A Female adapter. Then purchase a 3-light tester, with 3-pronged male 115v standard connector. Here is an example of one from HD: Gardner Bender 120 VAC GFCI Outlet Tester; 1/clam, 5 clams/master-GFI-3501 - The Home Depot
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 03-11-2015, 01:06 PM   #16
wmtire's Avatar
Don't know about a cupholder size, but I have this from the site below. It's a good site to have bookmarked as it has kind of useful information on RV electrical and testing.
RV Electric
Go to the "outlet testing" on left hand side
then scroll down and click on the 30 amp or 50 amp tester.
It takes a little to make these, but once done, they are easily plug and play
This link may take you directly to the 30 amp tester.
30-amp RV outlet Tester
and here is the 50 amp link
http://www.myrv.us/electric/Pg/tester_50amp.htm
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 03-11-2015, 01:20 PM   #17
DickiedooFlagman
Looks like that fills the bill. Very simple & does what needs to be done.
Old 03-11-2015, 01:26 PM   #18
Read my post three up. Two links there.
Edmund
VMI'62
Edmund is offline   Reply With Quote
Old 03-11-2015, 01:33 PM   #19
We've stayed at 65+ different campgrounds and I've only seen electrical issues at one (low voltage). My Progressive EMS checks everything before I hook power to the RV. So I'd say it's pretty rare to have a problem and not worth the extra worry of checking the pedestal before you start the set up process.
But definitely DO check the pedestal via one method or another.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 03-11-2015, 03:12 PM   #20
Thanks for all the feedback, that has helped answer that question. I am looking at getting and using one of the 30amp Progressive electrical protection plus that does testing as well as protects my unit.
VaTechMan is offline   Reply With Quote
