Old 08-08-2015, 11:05 AM   #21
I made a mistake I thought we were talking about sromburgs front rack. Sorry�� UI
NorSnrub is offline   Reply With Quote
Old 08-08-2015, 11:14 AM   #22
Originally Posted by Kansas Camper View Post
I do not use a weight distribution so that will not impact me. Still deciding between this model and the Arvika. Was hopeful somebody has one they could comment
If you hang a 100+ lbs of bikes and rack on your tongue, you may NEED a WDH.
2011 Traverse LT, 3.6L, FWD
Old 08-08-2015, 02:26 PM   #23
Doubtful. I have a Ford Excursion with Air Ride assist with the shocks. I pulled a 10,0000 lbs without a WD system.
Kansas Camper is offline   Reply With Quote
Old 05-02-2018, 09:40 AM   #24
QMastaD's Avatar
Did you end up doing this? I too have a 23IKSS and am looking at getting an Excursion. Is there enough clearance to turn with the bikes on there? How many bikes did you get on? I would like to get 4, but would be happy to get whatever I can on there.
Me-84, DW-86, My 3 Sons-08,10,12 and my baby princess-14
2015 GMC Sierra 1500 - 2014 Rockwood Roo 23IKSS
QMastaD is offline   Reply With Quote
Old 05-02-2018, 10:17 AM   #25
bikendan's Avatar
This thread is almost 3 years old and the OP hasn't posted since September 2015.
So I doubt that you'll get a response.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-02-2018, 12:00 PM   #26
Hello. No, I actually went a different direction. I took my 23IKSS to a Welder and discussed options. I ended up getting the Mount-n-Lock Safety Struts and had them welded to my back bumper. Then, I just installed a folding bike rack so I can fold it down to fold out the bed if I did not want to take off the bikes. I carry three bikes. It works GREAT!!!
Old 05-06-2018, 11:09 AM   #27
Ron045's Avatar
I working in a similar direction Kansas Camper. I installed the safety struts (although I bolted mine) and purchased an RV rack called Let's Go Aero Bike Wing. It's one 4 bike rack or two 2 bike racks.
My plan is to hang two off the rear and two on the A frame using either the Up-N-Front or the Arvika Travel Trailer A-Frame 2 Inch Receiver. The balance weight should nearly cancel each other out.
I'm just waiting for the Arvika people to tell me the height from the frame to the top of the receiver. The distance from the bottom of the frame to the bunk hinge is about 36". The Up-N-Front people told me that is enough room where I would not have to remove the receiver hitch to open the bunk.
I have also ordered a BAL Hide a spare. I did not like the fit of the bikes and the spare on the bumper. It made viewing the tail lights difficult.
Have Fun!
Ron
ID:	170802   Click image for larger version
ID:	170803   Click image for larger version
ID:	170804   Click image for larger version
Ron & Family
Sophomore Season (We're gonna color some states this year)
23 Nights in 2017
2017 Shamrock 23IKSS
2016 Lincoln Navigator L, 4x4, 4.10
Ron045 is offline   Reply With Quote
Old 05-06-2018, 12:27 PM   #28
Have Fun!
Ron
I added LEDs to my platform rack and wired them into the trailer wiring. Although you don't have a platform rack, you could probably figure out something similar.
Name:	6-Installed painted.jpg
Name:	8-Lighted turn signal.jpg
Also allows me to cover them without losing tail lights.
Name:	Mini Lite at Wolf River CG 1 Aug 2016.jpg
Old 05-06-2018, 07:06 PM   #29
Ron045's Avatar
Could you provide any pics of how you wired these up?
Thanks!
Ron
Ron & Family
23 Nights in 2017
Old 05-06-2018, 10:20 PM   #30
Thanks!
Ron
Don't have any pics of HOW they were wired. I just ran a 4-pin harness from the rear up to the junction box where the trailer umbilical goes into. Open it up and figure out which wires are which.
Here's a pic of the harness under the TT.
Here's a pic of your 7-pin showing which pin is which:
Name:	Vehicle 7-pin connector.jpg
Here's a pic of the 7 pin harness showing the colors of each function:
Name:	7-pin plug wiring.jpg
Here's a pic of a 4-pin harness showing the colors of each function:
Name:	4-pin wiring.jpg
Basically you run the 4-pin harness from your rear bumper up to the junctions box up by the trailer tongue. Open up the J-box and wiring the 4-pins left turn signal to the 7-pin's left turn signal wire (it will already have your trailers left turn signal wire attached to it). Do the same for the right turn signal, running light and ground.
(It's a good idea to plug your TV into the 7-pin umbilical and make sure you actually have turn signal power (for example) to the wire color you think it is. I've heard of some umbilical harnesses that weren't wired with the proper color convention.)
Then you wire your bike rack LED's in the same manner to the other end of the 4-pin plug.
Hope that helps.
UPDATE: I made a wiring drawing that may help you. See attached PDF.
