Old 09-04-2016, 09:52 PM   #1
RACarvalho's Avatar
Heads up for new IKSS owners
I went under my unit today " looking for trouble" and found this.
This is the big slide motor and the motor wiring was touching the manual over ride rod.
This would eventually eat all the wire insulation and cause a short....
I got the over ride rod out and put the wire on the other side of the motor so it will not touch anything that moves....
If you Have a Roo with big slide, take a look on that.
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
RACarvalho is offline   Reply With Quote
Old 09-05-2016, 10:58 AM   #2
cheeseheadjim's Avatar
THANKS for the heads up !!! I just checked my 23IKSS and do not have this issue, but I also secured the wire to be sure there is no future issue.
This forum is GREAT - these tips from fellow owners can really help avoid issues.
THANKS again for posting !!
Jim S
2018 Flagstaff 25FKS
2015 Ram 1500
cheeseheadjim is offline   Reply With Quote
Old 09-07-2016, 06:05 PM   #3
Thank you for the heads up! We'll put it on our list of things to check out when our 23IKSS arrives!
2017 Rockwood Roo 23IKSS
2017 Ford F150
2018 Days Camped: 34
2019 Days Camped: 5, but many more planned!
Maman325 is offline   Reply With Quote
Old 09-08-2016, 04:04 PM   #4
RACarvalho's Avatar
Maman,
This is the only thing I can think of that its not on the PDI list on the forum.
As suggestion for the first improvements, I added a clear plastic corner guard to the horizontal corners of the cabinet on the entrance of the beds, therefore they will not wear with traffic and if you hit your leg there, it will not hurt. Shop Miller LLC Clear Plastic Corner Guard at Lowes.com
We also added more shelves to the clothes cabinets so we can store more clothes.
Old 09-15-2016, 09:16 PM   #5
Originally Posted by RACarvalho View Post
Maman,
Thanks! We will add it to our PDI list or at least be sure to check it out while there.
And thanks for the cabinet corner suggestion - you must have suspected how clumsy I am!
2017 Ford F150
Old 09-19-2016, 01:56 PM   #6
Old Eeyore's Avatar
Stuff happens. . . I put corner guards from Menards in both of our HTTs. On the vertical corners by the door and the bottom of all cabinets. (I saw wear on those early on in the 21SS from dragging stuff in and out.)
X2 on those horizontal edges in front of the beds! Those things hurt like the dickens getting out of bed!
2022 Rockwood 2608BS / 2019 Silverado 1500
2016 Rockwood Roo 23IKSS / 2019 Silverado 1500
2011 Rockwood Roo 21SS / 2011 Tahoe
2006 Fleetwood Bayside / 2006 4Runner
1999 Coleman SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 10-19-2016, 03:00 AM   #7
stoppercamper's Avatar
Thank you!!! We will also add it to our PDI (Dec)
Can you post of pic of where you added the corner guards?
thanks
stoppercamper is offline   Reply With Quote
Old 10-19-2016, 09:31 AM   #8
I added the corner guards on pretty much everything. Inside the draws, the island - everywhere. I was under my 2017 IKSS and noticed the support bracket that goes from the black/grey water outlet to the frame came off at the frame and needs to be tacked on again. You may want to check that as well.
2017 Roo 23IKSS
2007 Tundra CrewMax Limited
Hemlock04 is offline   Reply With Quote
