01-27-2019, 11:44 AM
Heated Mattresses
Anyone else had their mattresses stop heating? Seems weird that all 3 of ours quit at the same time. 2014 Shamrock 183.
Bill
2014 Shamrock 183
1995 Chevy Silverado
01-27-2019, 10:27 PM
Do your AC outlets have power?
2013 Roo 19
2008 Toyota Sequoia 5.7 LTD
01-27-2019, 10:41 PM
the control boxes work off of 110 AC... You have 3 boxes... all of them should not quit working all at once.
Put an extension cord from 110 AC from somewhere outside the camper to the control boxes one at a time to see if they light up and heat the matresses...
If that works then you must have blown a fuse somewhere among the line.
The fuse box is below the fridge.
2014 Shamrock 183
01-28-2019, 01:04 AM
Wouldn't it be the breaker, not the fuse, since fuses are 12v DC?
01-28-2019, 07:03 AM
correct
switched breaker, not replaceable fuse...
both are located in the panel below the fridge...
2014 Shamrock 183
01-28-2019, 08:21 AM
Yes. All 3controllers light up. Just no more hat from either of the matresses. I’m gonna get ahold of a multimeter and see if I’m getting power out of them. It’s a three prong connection so I’m wondering what values would I check for at the connection of mattress for continuity etc.
Bill
2014 Shamrock 183
01-28-2019, 08:33 AM
I’ve got power and they do light up. I need to get ahold of a multimeter and check them. Im
Gonna assume the center pin might be ground and I should have power on the other two. I’m wondering if we haven’t wrapped the cords too tight for storage at some point and maybe broken a wire. We don’t use them often but when we do they are nice to have.
Bill
2014 Shamrock 183
01-29-2019, 08:50 AM
It begs the question that all three power boxes all break at once... chances are NOT
I suspect that the power boxes put out a low DC voltage from the output wire of the controller, increasing as the box is turned up to 5 from 1. ( just guessing)
you know the mattresses do not get HOT to the touch, like plug it in and I can feel them getting hot in 5-15 minutes, is not going to work.
Instead plug the mattress in, cover it with a sleeping bag or heavier blanket and in 30 mins you should feel a small difference of temperature next to the mattress then above the blanket. They make gentle heat...
I use my heating mattresses often in the fall and winter in the FL panhandle when overnight temps get into the 40's. Even with a mattress topper foam pad above the heated mattress it gets cozy.
2014 Shamrock 183
01-30-2019, 09:19 PM
That done it. Thanks. I put a comforter on it while tinkering with some other stuff and sure enough it warmed up.
Bill
2014 Shamrock 183
