Old 07-23-2012, 11:14 AM   #11
I checked this panel behind fridge. Everything looks good here. I dont have a voltage meter.....
rickysad is offline   Reply With Quote
Old 07-23-2012, 11:19 AM   #12
TURBS's Avatar
My point is you actually may have power to your motor and or switch but one of those pieces may be bad.
All fuses may be ok.
Untill you get a volt meter there's not much more to go on.
Believe me you'll use it more than this one time.
I bought one specificly for my camper and leave it there to check park power before we plug in and to diagnose electrical issues when needed.
Btw a visual look at fuses doesn't always mean there good or not blown..
Sometimes the only way to tell is to ohm the fuse.
Ron
Old 07-23-2012, 11:29 AM   #13
I opened this and found this but no fuse... Upper left of camper ... towards hitch:
Any more ideas? I am out of options.... Without a voltage meter.... However I have not identified a fuse...
Old 07-23-2012, 11:39 AM   #14
Ron and all , thanks for your help.... Time to go fishing! Any more ideas... I'll check back in an hour!
Old 07-23-2012, 12:27 PM   #15
TURBS's Avatar
did you find a curcuit breaker near the battery ?
sometimes they use a manual resetting type.
see the reset button on attached pic .
Old 07-23-2012, 12:58 PM   #16
Hi... No circuit breaker near battery . Ugh... I'm trying!
Old 07-23-2012, 03:38 PM   #17
Originally Posted by f1100turbo View Post
Attachment 16932
It seems like there are two things which 'might' look like this underneath... if this is it..how do you reset it?
Old 07-23-2012, 03:44 PM   #18
TURBS's Avatar
Look for that little button and push it if it has one.
Old 07-23-2012, 03:46 PM   #19
Send a message via MSN to dinda156 Send a message via Skype™ to dinda156
Rick:
Go find a Lowe's and pickup an el'cheapo VM. It will come in handy.
D
DTWGiggy
Sterling Heights, MI
2012 Coachmen Catalina 28DDS
2014 GMC Sierra 1500 SLT
Husky Centerline WDS
dinda156 is offline   Reply With Quote
Old 07-23-2012, 04:24 PM   #20
Control module... Black cord not connected.
Ahite cord dangling inside... I bet if I connect them...
You can just barely see the unconnected white wire... No other wires are in the wall. Should I connect them?
