Old 07-22-2012, 11:41 PM   #1
Help 2003 slideout fuse location
So here I am at the Monroe KOA , first time out with the fam in my Roo and the slideout just does nothing when I push the button. All other electrical works fine... It must be the fuse but where the heck is it???? I checked by the battery , underneath ( there is a metal box??? ) I looked under the couch but haven't pulled myself all the way under yet... It's a 2003 Roo 23 . Anyone know where the fuse is ??? Please help....
rickysad is offline   Reply With Quote
Old 07-23-2012, 01:40 AM   #2
If all else fails remove all outside power sources including 12v and remove the inverter. I found mine behind the inverter along with two other fuses. When you find it replace the fuse with a self resetting relay.
Ray
'04 Dodge 3500
'11 Flagstaff 8528RLWS, Hijacker 16k slider
HTR member Nights camped 2010 -115, 2011 -40 , 2012 -41, 2013 -86,
seatosea is offline   Reply With Quote
Old 07-23-2012, 08:07 AM   #3
Thanks Ray, where is the inverter? Sorry, I'm a noob!
Old 07-23-2012, 09:23 AM   #4
TURBS's Avatar
Its a converter not an inverter that he should have.
Fuse should be in distribution center where your 110 breakers are.
Old 07-23-2012, 09:25 AM   #5
TURBS's Avatar
Look for this.
Also you should replace fuse with a auto resetting circuit breaker of the same amps. Most likely 15 amp.
Ron
Old 07-23-2012, 10:13 AM   #6
I will check all fuses next...
Old 07-23-2012, 10:20 AM   #7
I check all fuses in fuse panel and all are good.
There is no fuse under couch.
There is no breaker\fuse by battery however
About 24 inches from battery under camper is what looks like a metal electrical box????
Please continue helping me ! Thanks!
Old 07-23-2012, 10:23 AM   #8
TURBS's Avatar
Lets start over a little bit.
1. Do you have power at motor?
2. So you have power at switch?
You need to check that first then report back.
Old 07-23-2012, 10:33 AM   #9
I push the out button and nothing at all happens. All other power works in camper. Best I can tell u ....
Old 07-23-2012, 10:42 AM   #10
TURBS's Avatar
I understand that.
You need to check actual voltage with a volt meter. Check incoming voltage to switch and outgoing voltage at switch. If that's good then you need to check voltage at motor.
Fuses may all be fine.
You may have a fualty switch or a bad motor.
If you don't have a digital volt ohm meter u better invest in one now.
You'll need it!
