Originally Posted by Northstar10
Have my Roo plugged into the house and getting no power other than microwave. Needless to say, but by no means am I an electrician or close to it. You can hear a fan come on when the lights come on they stay on for maybe 5 seconds then everything off again.
Oops won't forum
Any and all help would be appreciated.
OK, we're going to cover some basics real quick, and that may help figure out the problem
You RV has two electrical systems. A 120 volt AC system (like your house) and a 12 volt DC system (like your car)
OK, your microwave, television, air-conditioner, and anything that is plugged into an outlet has to have 120 volt AC power. You can only use these items when you are plugged into a form of this. Your microwave is operating, so we know you are getting at least 120 volt AC from your house to your RV.
Now, your lights, furnace, fans, pumps, radio.. run off of 12 volt DC (battery). When you are not plugged into 120 volts AC these items will still work, but just draw power from the battery. You have a neat little thing called a converter. This converter takes 120 volt AC and converts it to 12 volt DC to also power these 12 volt DC things when you are plugged into shore power so your battery doesn't have to. This converter also will recharge your 12 volt DC battery too.
You seem to possibly be having a converter problem, and could be hearing the fan in the converter coming on (which it should if there is a lot of draw on it).
Can you plug something into one of your RV's electrical outlets and verify there is power to it, or maybe turn on your television if equipped to also verify? This should let us know definitely if it's all going to be a 12 volt DC problem.....and we'll go to the next step.
