Old 04-23-2013, 07:31 AM   #1
RedStick's Avatar
Help me decide - portable tank options!
I've got a Roo 23ss and am in need of a portable tank.
It looks like the two brands of choice include the Barker Tote Along and the other manufacturer making the Tote n Stor.
I'm comparing the 22 gal Tote Along, 15 gal Tote Along with the 25 gal Tote N Stor and 15 gal Tote n Stor - all two wheel models.
For those that utilize the portable tanks, why did you select the brand purchased? Any issues with transferring the grey water to the portable tank? I've read comments from a purchaser that the high profile of the tote n store that some guy purchased was a few inches higher than his tank outlet. Seems to me that the force of the grey water wouldn't present an issue. Thoughts?
My grey water tank is 30 gal, but I'm not opposed to making a couple of trips if required. At the very least I'm looking to avoid having to hook up the Roo to dump the grey.
It seems like the tote n Stor offers a storage compartment for the gear needed, yet the tote along is a bit more expensive. What gives?
Thanks!
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 04-23-2013, 08:06 AM   #2
lswartz's Avatar
If it is just grey water, I use a 5 gallon bucket. Two trips each night I get rid of 8 gallons. At the end of the week the grey water tank is full & I can do a proper dump on the way out of the campground. This is not a good idea for the black water .
I would look at the smaller size just for ease of handling. Your DW might have to do this job sometime too, so size matters. I have seen some campers pull large tanks with their TV.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is online now   Reply With Quote
Old 04-23-2013, 08:11 AM   #3
We used a Barker when we had our popup and hybrid. Get one that you can tow slowely behind your F150. It makes the job alot easier in campgrounds with gravel roads or if the dump station is far from your site.
Old 04-23-2013, 09:07 AM   #4
You missed one big brand - Thetford Smart Tote.
I chose the Thetford product since I think that it is built better than the Barker - the other top choice. I got the 35 gallon tank since its capacity is larger than any of my tanks, and it works very well. You want to get one with 4 wheels, and the larger the wheels the better. Water is very heavy so you need to bear in mind that you will need to manually move the tank from the side of the RV to the truck.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 04-23-2013, 09:43 AM   #5
Sorry I don't want to change the thread here, but I was thinking of using a flojet macerator to pump it into a Portable tote as well! I don't have either yet! Instead of pulling the tote it would sit in the pickup bed and drive to the dump station. It would also solve the problem of RV drain being lower than top of tote. And how well do the flojet pumps work???
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 04-23-2013, 09:50 AM   #6
Triguy's Avatar
I have a Barker Tank - 32gl IIRC. The Barker is very well thought of amongst the RVing population. You can search here, RV.net and other places for details but my internet search several years ago pointed me to the Barker as the best of the bunch. Re: Wayne's Thetford - they might be as good or better. Thetford has a good name.
Remember that water weighs 8.35lbs per gl. So, filling up that 15gl tote makes it 125lbs with the weight of the tote (~10lbs). The recommendation to get one with sturdy wheels is a good one. You really don't want to try to man-handle one of these and you don't want it flipping.
I chose mine because it has four wheels and can be hitched to my truck. I've never filled it up completely, but its supposed to weigh 270lbs full. The smallest four-wheel job from Barker is their 16-gl and that weighs 135lbs full. Both of those weights are too much for me to lift so I figured I might as well go with the larger one.
But, I might do it differently now and get a smaller one. The 32gl tank is big and bulky and the Roos don't have a lot of storage for this size. Just some food for thought.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-23-2013, 09:54 AM   #7
Triguy's Avatar
I don't have one, yet. I've thought about it for pumping to my home septic but haven't pulled the trigger. I have see them at work and am impressed. Its been discussed a lot so here's some FRF search results in case you don't get anything else.
flojet macerator - Google Search
Scott
2012 Shamrock 233S
Old 04-23-2013, 10:01 AM   #8
I had one of the blue totes before but bought the Thetford (27 gal) this time. It seems to be well built, but there are a few stupid things wrong with mine.
1) The printed instructions for removing the vent assembly tell you to turn it the wrong way. They've corrected it on-line and I assume they'll sell out of the "wrong" ones after a while.
2) The screws that attach the handle to the tank are too short to reach the nylon in the nylon lock nuts. I lost one first time out and replaced it (and the others) with 1-1/4 stainless.
3) The four washers on the main axle are all behind the wheels. I'm quite sure that one should be on the outside of each wheel, behind the press-on nut.
Still, I'd buy it again. The front swivel wheel is heavy-duty and I like the way it attaches to a hitch ball.
Old 04-23-2013, 10:18 AM   #9
Fulltime family RVer
I think this is the best answer (even for the OP). There's no manhandling a heavy tote and no driving extra-extra slow through the campground.
Now, if my family wasn't a bunch of Wookies- I'd consider one. For now, I only camp with full hookups.
Old 04-23-2013, 10:31 AM   #10
I also have a barker 32 gallon 4 wheel and love it! I had a barker 25 gal 4 wheel and also loved it I wanted more capacity but 42 was to tall. All my friends laught when I bought it now they all use it. Trust me get a 4 wheel either way you go they get very heavy. Call barker direct they sold me the tank and electric tongue jack direct.
CincyED is offline   Reply With Quote
