Old 11-18-2014, 05:09 AM   #1
myfirstroo21ss's Avatar
help pipes are frozen
I went to winterize my 21ss and the pipes had frozen. I have turned heat on and used an electric heater as well to get the pump thawed out. I had to do the same with the hot water heater as the valves wouldn't close. Once they thawed I bypassed the water heater and drained the heater of the remaining water. I have pumped 4 gallons of antifreeze through the system but I do not get anything out of any of the faucets or showers. Any suggestions? It has t even been that cold here in Connecticut. Thanks
myfirstroo21ss is offline   Reply With Quote
Old 11-18-2014, 05:27 AM   #2
Witch Doctor's Avatar
How did you pump 4 gals in ? Your plex lines couldn't hold 4 gals. It has to have gone somewhere, Did you check your lines for any breaks? Might all be sitting in your under belly. I hope not...Good luck.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-18-2014, 05:28 AM   #3
Oaklevel's Avatar
Sounds like you still have ice blockage . Where did 4 gallons go. Did any run out on the ground?? or were the valves really closed to the hot water heater?? No huge deal if it went into the hot water heater until later more flushing in the spring. If it did the hot water heater holds probably 6 gallons depending on what you have. Our trailer is 36' & take less than 2 gallons to have pink running out of all the faucets. Do not forget the toilet.
Good Luck
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 11-18-2014, 05:30 AM   #4
I was doing it last night in the dark but I couldn't find any leaks. If you turn the pump on you can hear the water near the hot water heater.
Old 11-18-2014, 05:54 AM   #5
I was finally able to get a little pink out of kitchen faucet and the outside shower as well. The anadode is out of hot water heater so if it wasn't bypassed it would run out of it correct?
Old 11-18-2014, 07:05 AM   #6
Taranwanderer's Avatar
Yes, if you have the anode out and anything runs in there (AF or water) it should be flowing out the hole (if the trailer is level.) So the question remains--where did the 4 gallons of AF go? If it didn't come out of any of the faucets, shower head(s,) ice maker (if you have one,) or toilet, you have a leak somewhere (possibly open low point drains?) or a cracked pipe from the ice.
Are you sure the pump actually sucked out the jugs of AF? (I know, stupid question.) Just because you hear the pump running doesn't mean its actually sucking, especially if its blocked with ice...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-18-2014, 07:17 AM   #7
All set! I put an electric heater near hit water heater and then got another gallon of antifreeze. There must have still been blockage. Thanks
Old 11-18-2014, 07:22 AM   #8
OK, that's great...but it still doesn't explain where that first 4 gallons of AF went...you don't see any AF leaking anywhere that it shouldn't be?
Old 11-18-2014, 07:27 AM   #9
It was probably a little less than that because I filled the filter housing and it was cracked so I had to buy a new one. Even still seems like a lot but I don't see any leaks anywhere. Fingers crossed!
Old 11-18-2014, 07:39 AM   #10
fonzie's Avatar
Did you put the 4 gallons in the fresh water tank and then used the pump or if you have an external winterizing connection used that?
Fonzie
