Old 05-14-2016, 08:53 AM   #11
dcheatwood's Avatar
Another happy ending. You frf guys are great.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-14-2016, 12:19 PM   #12
I like the way everyone chimes in with input. You guys are outstanding. Love this forum
bigdogg is offline   Reply With Quote
Old 05-14-2016, 12:39 PM   #13
I have a Flagstaff MicroLite RV. I have learned that too much weight on the slide-out will often blow the 30 amp inline fuse, whether extending or retracting the slide-out. Minimizing the weight will make the fuse last longer; an electrical engineering friend of mine calls it a design defect because the slightest interference with the slide-out's travel will blow the fuse. I keep a package of 30 amp fuses taped to the slide-out for easy access, and a large body pillow to cushion my body underneath the trailer's tongue while replacing the fuse. Happy camping!
Hector517 is offline   Reply With Quote
Old 05-14-2016, 12:50 PM   #14
Iwannacamp's Avatar
Everyone needs one of these. Good for the knees also...
Name:	ImageUploadedByForest River Forums1463248191.439585.jpg
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-14-2016, 01:37 PM   #15
Here is the re-settable circuit breaker we used.
I removed the 30A fuse and holder from under the trailer and installed this one in the the hot wire right next to the slide motor (in our case, under the couch).
No more replacing fuses under the trailer, usually when the ground was wet!!
Henboy is offline   Reply With Quote
Old 05-14-2016, 06:07 PM   #16
We had the sMe thing happen withe our ROO 21dk the first time out. Took us hour and phone calls to a dealer then FR. No one knew what it was so we ended up calling a mobile RV repaire service. Once he looked at it all it took was the 30 amp fuse. Live and learn.
Ncgrandma is offline   Reply With Quote
Old 05-15-2016, 06:56 AM   #17
Wolverine 1945's Avatar
Glad it all worked out,,, and hope you have a great trip !!!
May I suggest that next year,,, if you have time check things out a little more in advanced,,, you never know what you might find ???
Wolverine 1945 is online now   Reply With Quote
Old 06-13-2016, 02:28 PM   #18
RooRyder1911's Avatar
Thank god for this forum had same issue, would have had to bring back to dealer . Never would have been able to figure it out on my own.
RooRyder1911 is offline   Reply With Quote
Old 06-13-2016, 02:34 PM   #19
BandJCarm's Avatar
Attachment 107856
I simply don't see how that's going to help me get up...........
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-13-2016, 08:04 PM   #20
Iwannacamp's Avatar
Lol. I use whatever I can lean on to get up. Have folded it half many times in used it for a push up post.
Dang I'm old.
2017 Puma 297RLSS
