Old 05-13-2016, 12:35 PM   #1
lablover's Avatar
Help, We got nothing
We have a 2015 Roo 21BD and when opening it up to prepare for our 3 month trip which starts next week the slide is not working. There is no noise and no action. Checked fuses in fuse box inside and all appear intact, Checked batteries and both register full. Everything seems to work on electric and battery inside. Everything worked fine last fall when we winterized it. What are we missing? Is there another fuse box somewhere? or reset button that we don't know about? I am hoping it is something simple, don't we all. Of course local FR dealership is busy and I get that. We do know how to use manual crank to get it out and in but hoping we can resolve this with your help. Thanks
2 Old Geezers
2 Labradorables
2015 Dodge Ram 1500-Rambo
2015 Roo 21BD-L'ABode
lablover is offline   Reply With Quote
Old 05-13-2016, 12:39 PM   #2
How about a inline fuse?
dblr is online now   Reply With Quote
Old 05-13-2016, 12:50 PM   #3
clr
Many Ultralight TT have an inline fuse because the wires go from the slide directly to the battery. Many times there is reset able fuse on that wire on the tong of the TT. Look for a fuse that looks like the below. OK the picture does not want to post but just push the little button on the side and reset the breaker.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-13-2016, 01:10 PM   #4
fonzie's Avatar
X2, usually underneath tongue of trailer
Fonzie
Old 05-13-2016, 03:24 PM   #5
lablover's Avatar
Thank you so much. Looks like this may be it. I am on my way to Walmart to get some new 30a fuses. I will let you know.
2 Old Geezers
2 Labradorables
Old 05-13-2016, 04:19 PM   #6
Mainframe's Avatar
Here is what you need, a 30 amp circuit breaker
Name:   ImageUploadedByForest River Forums1463174342.530189.jpg
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 05-13-2016, 04:28 PM   #7
lablover's Avatar
PTL and the FR Forum. It was indeed as simple as that. Problem solved. Thanks you guys-you are the best. Now its back to packing and restocking. Just a little hiccup along the way, and a simple and cheap one at that.
2 Old Geezers
2 Labradorables
Old 05-14-2016, 05:06 AM   #8
Glad it was a easy fix now enjoy your camping trip
Old 05-14-2016, 06:02 AM   #9
Herk7769's Avatar
One of the things that blow that fuse after a long winter's rest (with the slides closed) are the seals.
Now that you have them open, treat them to a good cleaning and spray with RV Seal treatment (basically silicone spray).
Thetford-32778-Rubber-Seal-Lubricant
HAM CALLSIGN - KC3FFW
Old 05-14-2016, 06:23 AM   #10
cheeseheadjim's Avatar
Glad it worked out for you. This forum is the best!
2018 Flagstaff 25FKS
2015 Ram 1500
cheeseheadjim is offline   Reply With Quote
