Old 03-28-2015, 11:36 PM   #1
Help with furnace in my 23IKSS
Hello everyone. We have our new to us 23IKSS Roo, and have been outside in the frigid temps and snow of CT, trying to prepare her for our maiden voyage early in April. I wanted to turn the furnace on because it was so cold in there, but to no avail, I could not get it to blow hot air. Now here's the silly question: does the furnace ONLY work on propane? I did not try that option, as I wanted to heat it by using my electricity. I would hate to blow through so much propane heating the camper for our trip. Can anyone tell me if it's possible to run the furnace on electricity only? And how to do it? I thought it was a simple as putting the system on heat and setting your desired temp of the thermostat. Guess not.
I have a portable ceramic heater in there now, just to get the temp up a bit and make it possible to stay out there while we clean it out and prep it for camping. Any help would be appreciated. We only had a bare bones pop up before this, so we are real rookies at all of this.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 03-28-2015, 11:44 PM   #2
deartruc's Avatar
yes sewingcybermom, the furnace is propane only. You may need to light your stove first to make sure your gas is flowing and get it closer to the furnace. PS Electric heaters work great.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 03-29-2015, 03:12 AM   #3
bikendan's Avatar
yep propane only, along with 12v battery power to light it and run the fan.
your dealer should be ashamed of themselves for not explaining that during your PDI.
i know of NO RV that has anything but just propane heat, unless some high end motorcoach or a custom build.
most of us do what you did, bring a ceramic heater or two or a oil-filled radiator type of heater, when you have hookups.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-29-2015, 06:55 PM   #4
i agree with post #3. electric heaters are better if you have shore power, don,t waste your propane.and you will use a lot of propane running the furnace.
muskoka01 is offline   Reply With Quote
Old 03-29-2015, 07:31 PM   #5
bikendan's Avatar
but if you don't have shore power to run the heaters or furnace, you'll run out of battery power WAAYYY before you run out of propane.
Old 03-30-2015, 12:50 PM   #6
Stormrider151's Avatar
When we ordered our new trailer we included the "fake" fireplace. I thought it was just a gimmick for the longest time but turns out it actually is a heater. It runs on electricity but that's the only RV heater I know of that does.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-30-2015, 01:00 PM   #7
Glindz233s's Avatar
Furnace works on propane only. A small portable electric heater is a must in cold weather. Even so, don't expect to be in the 70's inside when it's 30/40 outside. We set our heat at 55ish and let the electric heater do more of the work. Still need blankets and/or sleeping bags on top.
Our heater died on our first cold night camping and we had no electric heater with us. Good thing we had our sleeping bags with us. Dealer replaced it under warranty.
Me, Wifey, Thing 1 & 2 plus Gracie the Shitzu rescue
FR Shamrock 233S 2015
2018 Ram 1500 Hemi 5.7 4x4 3.92
Nights Camped: NOT NEARLY ENOUGH!
Glindz233s is offline   Reply With Quote
Old 03-30-2015, 04:25 PM   #8
Well, just to clarify, there is no dealer involved. We purchased our 2014 from a private seller. I thought it was propane only...we finally got it to work, thanks to everyone here. We plugged in our little ceramic heater, and it worked great to heat the camper last night. But today, I wanted to vacuum the camper and when I started the vacuum, I tripped the breaker. Sooooo...if I run the heater, I can't run anything else electric? I tried to plug the vacuum into every socket in there to see if any ran off a different breaker..no go. What can I use while the heater is plugged in without tripping the breaker?
Old 03-30-2015, 06:10 PM   #9
rbq
Depending on the heater you will probably need to turn off the electric heater to run other appliances, such as a toaster. We found we can't use the electric heater & toaster together. Have to turn off the heater, use the other & then turn the heater back on. All of the outlets are probably on one breaker and of course go through the GFI outlet in the bathroom. You can run low draw items like a TV or phone chargers as they don't draw much power.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 03-30-2015, 06:11 PM   #10
Glindz233s's Avatar
Probably will just have to unplug the heater then vacuum. I tried running two electric heaters and it was too much for the breaker. Didn't try using anything else.
Hopefully you got the manual and some instruction from the prior owners. If not, go check out the manual and videos on the forest river website. They help some along with this site.
furnace
