Old 10-22-2011, 06:04 PM   #1
Here Goes Nothing
Well we left Toronto area on Friday morning at 4am headed for RV Wholesalers down in Lakeview, Ohio. We were on our way to pick up our new Roo 183. We got there 10 minutes before our delivery time of 11:30. Cool. The RVW rep (Mike) did the walk through and demonstration. We had no issues and were anxious to get away. So we got on the road headed back up to Port Huron and the KOA. We finally rolled in at about 7:30 or 8pm. So the first set up took place in the dark. Very hard to see if it was level or not. Make a note to bring a level next time. Everything went well, with the family eating our first meal in our new RV. Lasagna, and it was good too with lots of garlic bread.
That KOA is absolutly beautiful. We were very sorry we couldn't stay longer to enjoy it more.
So after the water and electrical hook up, we started to really look at the new RV. Everything seems to work fine. Plugged in and used the heated mattresses and boy did we need them. The heater quit after the first try. Not sure why. I'm going to look at it tomorrow. Any suggestions? As i said it worked once and blew heat and then packed it in.
All in all though the trailer is a thing of beauty, we love it and can't wait to get out somemore in it.
Roopert21bh is offline   Reply With Quote
Old 10-22-2011, 06:14 PM   #2
Boyd's Avatar
Level: I use a marble on any flat surface for leveling.
Heater: Gas furnace or electric plug-in type heater? #1 check breakers.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-22-2011, 06:20 PM   #3
TURBS's Avatar
could have been air in the line ?
run your stove burners for a bit to try and help clear air if thats maybe what happened.
Old 10-22-2011, 06:53 PM   #4
No Dice
When i first fired the furnace, the fan came on followed by the ignitor, followed by beautiful warm air (and trust me we needed it last night) after that there was nothing. Not even the fan coming on.
Old 10-22-2011, 06:56 PM   #5
I bled all the lines and let the stove tops run for at least 3 or 4 minutes. So it couldnt be air in the lines. And i checked all the breakers by turning them off and then back on again.
I was looking at the wiring diagram and i think the furnace might have tripped a manual reset high limit control. Tomorrow I'm going to get in there with my meter and figure it out.
Old 10-23-2011, 09:09 AM   #6
hockeytownmom's Avatar
I don't think my furnace works properly either. But I think we're just going to use an electric one from now on.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 10-23-2011, 09:17 AM   #7
(Kim)
Labzy's Avatar
Hmmm what is the thermostat at?
Maybe it is not coming on because the thermostat is set at too low a temperature.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-23-2011, 03:25 PM   #8
Ok, thanks for all your posts in response. I have the definitive answer on this and here it is.
Suburban, the maker of all things appliance etc for RV's.... are a bunch of Ass Hats. It's obvious they never have to service their own product because they couldn't make things more service unfriendly if they tried.
I got into the problem with my heater today and here is what i found. All the electrical elements of the heater are located on the side of the heater, thus you have to disconnect the gas and all venting and electrical to pull said heater from the location. Next you must pull the actual heater from it's tin shell/sock that the heater is actually in. This shell does two things. It serves for somewhere to bolt/screw the heater to the Rv and also acts as a plenum for you to hook your flexible ducting to. So now I have the heater out and sitting on my RV table to access the electrical
I was passing voltage at the thermostat. Next in line is what Suburban call a 'valve switch'. This is in fact simply an on/off toggle switch. This couldn't be the problem area, because it is a positive off/on switch and the switch was in the on position. Next in line is sail switch or a limit switch, i can't remember which. The sail switch is there for when the therostat calls it immedialtly starts your fan, once the sail switch closes, inidcating you have air flow, the ignitor sparks up your flame and you get warm air.
I figured either the sail switch was defective or the limit was defective. Remember this is a brand new unit, and **** happens.
As it turned out, it was an interresting problem. This is what makes life worth living. The sail switch was getting hung up on a piece of the heat exchanger and when the fan turned off after the heat cycle, the sail switch would remain closed. The electronic board/brain which governs all. looks at it and says, 'well I turned the fan off, why didnt the sail switch open...Houston we have a problem...no more heat untill someone fixes the problem or the sail switch opens'
So in a nutshell, i trimmed back the sail switch's main sail (lack of a better term) so it would always clear the heat exchanger and put it all back together. we have heat. My wife thinks I'm a genious, brings me beer and gets naked. could life get any better...oh and don't mention the wifes sister that gets said beer cut off and clothes back on.
Best regards, my next mission will be to put an electronic thermostat in.
But you know, why would anyone want to burn their propane, when all the campgrounds offer their 30/50 amp service, and you could pick up a little cube heater that runs at a fraction of the noise that the propane does, and runs off their electriciy. That's my next buy, and I'll save the propane for dry camping.
Old 10-23-2011, 04:17 PM   #9
Hoo Dad's Avatar
OK, I'm impressed. I would have to take the camper to the dealer to get repaired. I would still get the beer and hopefully all other perks but I would be in the hole a lot more money.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-23-2011, 05:03 PM   #10
Boyd's Avatar
Trim the sail, maty
And you get a big "atta-boy" from this old dog. Salute
