Old 10-16-2016, 06:17 PM   #21
Originally Posted by Skyliner View Post
This is a common issue with most campers and not really caused by overloading tanks. I had a tank that was only 1/2 full fall off on me.
The solution is to reinforce the brackets with perpendicular brackets that keep everything in place and prevent the tanks from falling thru.
Every camper I've purchased since my tank fell off has had the tanks brackets modified. Its no big deal, better to fix it before it falls out, much easier.
Do you have photos or details of your reinforcement?
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 10-18-2016, 03:44 AM   #22
Mr Havercamp's Avatar
Originally Posted by rockfordroo View Post
Mr Havercamp had the same problem. Here's the thread:
water tanks falling out
I don't know why his pics are missing, though. If you PM him, he can probably email you his pics and his fix.
The pics are missing because I deleted my photobucket account. I will send them when I find which one of my drives I dumped them on. The fix was heavier angles. The supports are under engineered by the manufacturer, Lippert Components (LCI). For laughs call them and report the problem. The him hawing and red tape run around they perform is amazing. One of the main criteria for our next trailer will be which brand/model has the least LCI stuff on it.
Rockwood uses the cheapest fresh water tank they can find. Then they jam it tight to the floor. You do not think the top will balloon up when filled??? Think again. Have the camper an inch or two out of level side to side and see what happens. The floor is oly attached to the frame at the perimeter where its bolted to the outriggers. The tank is essentially a jack and will arch the floor up if you fill it full when out of level.
In contrast the second tank I added which was made by Aplha is much thicker plastic with rounded corners and does not balloon anywhere near as much as the thin cheap tank Rockwood used. I also installed both tanks with a 3/4" gap to the underside of the floor.
Mr Havercamp is online now   Reply With Quote
Old 10-20-2016, 01:27 PM   #23
Water Tank issus
Some of you may find that when FR went to the wider body trailers they did not have the company who supplies the frames put in heavier angle iron that the front of the water tank sits on. They did put in heavier angle iron in the rear that they install and because of the extra width the front angle iron was not able to handle the additional flexing that the full water tank put on it. It caused deflection on the front angle iron and caused the tanks to drop out.
So check your units to see if you have different (Gauge )thickness on the font angle than in the back. If so then this is a design flaw that FR is aware of as it has been brought to their attention and maybe you can get them to pay for your repairs.
Ca Cardinal is offline   Reply With Quote
Old 10-20-2016, 02:55 PM   #24
same issue
While filling my tank for hunting camp, the fill hose came off the nipple on the tank. Water everywhere. Had to remove the front support bracket which is attached by self taping screws to lower the tank to gain access to the fill tube and attempt to reattach it. The support brackets are not strong enough and the tank can move side to side which was the main reason the hose came off in the first place. Another project to do next spring.
isp435 is offline   Reply With Quote
Old 10-21-2016, 02:21 PM   #25
River Forest Sunseeker 24
I find it astonishing you could make this tank balloon up and fall off! What kind of plastic is this made of? How could it handle the heat of traveling down the highway?
If I had read this forum prior to buying a motorhome, I would not have the courage.
Ignorance may not be blissful either.....
Nancyc7 is offline   Reply With Quote
Old 10-28-2016, 02:40 PM   #26
It takes only a few psi ............. and a lack of engineering
Originally Posted by Tireman9 View Post
Not sure how you "overfill" a closed tank. Water weighs about 8# a gal and the tank capacity is fixed. The RV company knows the static weight and should of course account for bouncing which could double the weight. So full is full.
Water pressure doesn't enter into the question as there is nothing for the water in the tank to press against other than maybe 50 psi for the area covered by the fill pipe diameter.
Any competent engineer can establish a minimum metal thickness to support the water tank.
As posted, the tank is plastic and can expand. It takes only a few psi to do this. Mostly the large flat top and bottom sides expand outward.
Your assumption about competent engineers is optimistic. I have a Rockwood Ultralight and there is a lot of terrible engineering in it and that is compounded by poor assembly and a total lack of quality control (I'm an engineer with 50 years of experience so am qualified to judge). I've had over 25 significant issues that have required about that many days to rectify. I come back from each outing with a new list of things that need fixing, most that should have never happened or should have been fixed via quality control.
Hclarkx is offline   Reply With Quote
Old 10-28-2016, 02:47 PM   #27
The large flat top and bottom do the bulging. Blow into an empty gallon milk container and with just a few psi the flat sides bulge outward. With enough pressure it will turn into a balloon shape because that shape has the greatest volume. The tanks on some of our RV's don't have walls much thicker than that milk jug (yes, thicker, but not enough to prevent bulging of the flat sides).
Old 10-31-2016, 07:05 AM   #28
Dave Lyon's Avatar
It seems odd - it appears that the tank is pressurized?
I fill my FW tank until water runs out of the vent hose and never had a problem....maybe I'm just lucky and on borrowed time.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is online now   Reply With Quote
Old 10-31-2016, 07:20 AM   #29
KyDan's Avatar
Possibly! It's possible to shove a cut off hose deep into the gravity fill and
turn the faucet on full blast and when the tank is full the water would not
be able to get out the overflow fast enough. City water pressure on a full
tank will definitely bulge the sides! The bulging sides pressing up against the
floor can easily bend the supports and drop the tank.
Pulling off the belly cover and inspecting my water tank supports is on my short list but
I haven't done it yet....
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
Old 10-31-2016, 02:09 PM   #30
Better safe than sorry .................
I do likewise, but from what I'm reading here, the fresh water (and probably the other tanks) may have very little margin in their supporting brackets.
Sometimes we have to drive some distance with a full tank (from fill station to the site or from the site to a dump station) and I have to wonder if a large pot hole or speed bump might drop a tank through its supports.
I too am going to have a closer took even though it means taking out hundreds of screws to drop the bottom cover.
fresh water, tank, water, water tank
