Old 07-15-2016, 08:22 PM   #11
Mainframe's Avatar
Wal mart has them
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 07-15-2016, 08:37 PM   #12
Flybob's Avatar
X2 on the 50A to 30A adapter. You will run into this situation again for sure. Just because 50A is available, you will be limited to 30A by the breaker in the RV.
The service station where you bought your fuel had a 3000 gal fuel tank but your TV stopped taking fuel when it was full.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-15-2016, 09:26 PM   #13
raspivey's Avatar
Originally Posted by Summer2Go View Post
I have that to plug in my driveway. I'm trying to make sure I can use 20 amp. I have a heavyier outdoor extension, 13 amp, and the camper adapter that goes from 30 amp to the extension cord. Can I just plug that into the pedestal, the plug into that or is 20 amp a bigger plug?
Yes, the 20A pedestals will handle the 15A plugs. No additional adapter needed if you've already got one to take your 30A down to a household extension cord. The plug will be the same. Again, your weak link will be that section of cord that is less than 20A and possibly the adapter, depending on the quality. Be careful what you run. For instance, my AC units show about 12-14A continuous when running hard. A smaller gauge cord will increase voltage loss and increase amp draw, which makes heat. Your AC alone could be drawing nearly 20A with an extension cord and, while the breakers will take it, that 13A cord might not.
2012 Chevy Tahoe LTZ - HD tow package
Old 07-16-2016, 01:27 PM   #14
At home I only have 15 amp service outside so I use a 50amp to 30 amp adaptor, and a 30 amp to a 15/20, all are which are available at pretty much all RV supply stores. Also, some campgrounds that have only 15/20 amp service sell the adaptors as well. Just remember to keep your usage down. My AC won't run on 15amp service, and if you run a coffee maker and microwave at the same time you may blow s breaker. And make sure any extensions you use are appropriate for the amperage, or you may blow more than a breaker, and that wouldn't be fun.
DrLewie is offline   Reply With Quote
Old 07-16-2016, 03:13 PM   #15
Talking No power
On our trip to Alaska we stayed in many campgrounds that had no power what so ever. We learned to not have any lights on that we did not need. We got along just fine on battery power.....we do have 2 batteries so that helped. A good assortment of adapters is a must if you plan on traveling ......
Bob Vaughn is offline   Reply With Quote
Old 07-16-2016, 05:09 PM   #16
You can plug a 15 amp cord into a 20 amp receptacle but not the reverse. I'd just get a
30 amp (F) to 15 amp (M) adapter and plug it into the 20 amp receptacle at the park.
Just watch what you're using at any given time and use propane where possible. The worst that can happen is you'll keep tripping the breaker if your load is too high.
Larry Cole is offline   Reply With Quote
Old 07-17-2016, 07:06 AM   #17
65 days camping in '11
I use a 15M to 30F adapter. Doesn't need to be a 20M which would prohibit use on a 15 amp circuit. Plug in shore power cable, plus shore power extension if needed for distance. If your shore power cables are 50amp then add a 30M to 50F adapter to the 15M to 30F adapter. You oughta already have the 30-50 and shore power extension. Nothing is different from the 30amp (or 50amp) on the adapter to the RV. Can't run A/C and fridge at same time. Run fridge on propane.
kbradley is offline   Reply With Quote
Old 07-17-2016, 07:16 AM   #18
Professional Curmudgeon
If 30 amp service isn't available, then, yes, you can use the same stuff you use in your driveway.
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 07-17-2016, 07:34 AM   #19
GalsofEscape's Avatar
My Roo has 30 amp service and the power cords & surge protector for it. How do I use the power for 20 amp? They have 50 amp there but not so many. I thought people adapted for 50 amp, but my surge protector is 30 amp. Do I just not use it?
I see you are in New Jersey - and I am curious - where are you going that does not have 30 amp service?
The state parks I have been to so far (Pennsylvania, Maryland, New York and South Carolina) has had at least 30 amp at the electric sites ....I do have a 50 amp adapter, have had it for 6 years and have never used it as 50 amp power poles also have 30 and 20 amp service at them. I use a 20 amp adapter at the house, but I am not running any appliances - it is only to power up the battery and lights if I need them.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
Traveled 19520 miles and 209 nights in 7 years and counting
GalsofEscape is online now   Reply With Quote
Old 07-17-2016, 08:00 AM   #20
Mr Havercamp's Avatar
There is at least one PA state park who changed the service amperage in their information, brochures, and on the reservation sites. Even though installed as 30 amp with 30 amp receptacles under the codes at the time, they now show sites as 20 amp. The systems for the most part now get grossly overloaded on busy weekends. When a lot were put in back in the 70's/80's AC was a luxury few had, microwaves did not exist(at least for the average persons use at home let alone in an RV), residential refrigerators were in residences etc.
Now people reserve a site which was originally wired as a 30 amp service to 40 year ago specs and codes, they dogbone their 50amp service and fire up both AC's and the residential fridge, and when they try and nuke the Hamburger Helper one of the AC units implodes and the main power cord melts due to low voltage and too much load. Then they expect the DCNR to pay for it. Now they list the sites as 20 amp. Not only does it give them some more ammunition when someone comes after them to pay for their stupidity, but when someone complains they can't use their dishwasher, clothes dryer, 2 AC's, fridge, and toaster all at the same time and they want a refund, they can be told the site was advertised as 20 amp so you should of taken that into account before booking it.
The Superintendent is pushing for funds from the powers that be to upgrade but with control changing every few years thats not easy. I told him I thought the best upgrade would be just ripping out all the pedestals and disconnecting it all. The park campgrounds were built to be just that, campgrounds and not RV resorts.
2017 Roo 23WS
2015 GMC Sierra 2500HD 6.0 DCLB Z71
Mr Havercamp is offline   Reply With Quote
camper, service
