06-07-2014, 09:50 PM
Hitch Pin Grades
I recently purchased a Reese coupler locking assessory kit which included a locking hitch pin. In my years of pulling trailers, I've never questioned the "grade or strength" of different hitch pins. Is there actually different grades of of pins for 2" receivers? For some reason I called into question it's strength as compared to others non locking (regular) pins I have. Comments??
Roocrew1 FL
2012 233S
2010 Expedition EL Limited 3:73 with Air Suspension
06-07-2014, 09:59 PM
When I had my bumper pull trailer last year, I purchased a Reese locking hitch pin. Used it one time for about a 6 hr round trip and it was bent. Trailer was 30ft and just under 8000 lbs loaded.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
06-07-2014, 10:15 PM
Location: Alberta - East of the Rockies, West of the Rest
Excellent question, I wondered that myself.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
06-07-2014, 10:23 PM
Today I bought a new Harbor Freight locking hitch pin for $10. I too got to thinking that this $10 pin is holding everything together and wondered just how good is it. Oh man, another night of not sleeping.
Mark and Joanne
06-07-2014, 10:25 PM
I guess they have to be fool proof and handle the standard load applied to a standard receiver... Never seen an accident or loss due to a sheared pin.
Roocrew1 FL
2012 233S
06-07-2014, 10:31 PM
Besides, my Harbor Freight pin comes with a 3 month warranty.
Seriously, I pulled my last trailer, loaded about 7,500 lbs for over 16,000 miles over 2 years with no issues other than surface rust.
There sure is a lot of weight on a small surface area. But you never do hear of a pin failure accident.
Mark and Joanne
06-08-2014, 01:47 AM
Just a member
If the locking hitch pin is intended for a Class IV hitch, I would expect that it would be rated for at least a 10K lb pull. We have the Master Lock variety. It's seen three yrs and over 12K miles tugging ~7500 lbs. No issues save for a little abrasion to the chrome finish.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
06-08-2014, 05:15 AM
The (shear strength) of (1.250 CRS) would be Much higher than any Numbers used in this Post! Very few applications of a hitch are (Direct Pull) unless You are (Pulling Stumps)? Youroo!!
06-08-2014, 06:09 AM
I think the hitch pins are 5/8" dia (0.625").
06-08-2014, 08:03 AM
not sure why I still have it, but here it is after 1 trip
Sent from my SCH-I535 using Forest River Forums mobile app
06-08-2014, 08:22 AM
if you send that pin to me I will test the hardness of it with a rockwell tester, I bet any money it made it thru manufacturing with out heat treatment and is still in the Annealing condition
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
06-08-2014, 08:37 AM
That's tempting, and I appreciate the offer, but I'm not sure I even want to know how close I was to testing the hardness of the safety chains
06-08-2014, 08:45 AM
If I send my wife, can you test her to see if she's been tempered? Lol
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
06-08-2014, 08:50 AM
I had same issue right after I bought my TT. After a 1800 mile trip, the cheapo pin bent enough that I had to hit it out with a drift pin. Threw it out and bought a SS Reese locking pin. Still like new.
2000 Cherokee, 400w solar, 6v batteries, flipped axles, LEDs, etc. 2007 Tundra DC-LB, modded as well. C-co, 8/158th AVN Maint.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
06-08-2014, 08:56 AM
that's exactly what I bent in one trip. Thought I was getting quality when I bought a Reese product
06-08-2014, 09:02 AM
Infractee
Most of the Reese stuff I have seen is import, including hitches and 5th wheels that is why I went with B&W.
An adage I use concerning Harbor Freight is "If your life or your job depends on "it" then do not buy "it" from Harbor Freight"
Your life may not be in jeopardy from a chinese hitch pin but the poor schmuck driving behind your camper may have a little more money in the pot...
Not bashing HF, have a bunch of stuff from them but not anything that I depend on.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
06-08-2014, 09:51 AM
Yes they are (.625) I said (1.250) because you would have to (Shear (2) sides X (625) = (1.250) Youroo!!
06-08-2014, 10:19 AM
I sometimes run a 1 foot hitch extender and use grade 8 5/8" bolts in both holes. But in 23 years working as a fleet mechanic I have never seen a hitch pin failure.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
06-08-2014, 10:22 AM
Shear strength on a 5/8" type 2 bolt is 13,621# and considering it has to shear 2 sides, it would take 27,242# to shear the pin. No way it would have sheared. Just because it bent does not have anything to do with shearing it.
Bending is definitely not good, but that just makes it very inconvenient to remove, nothing else.
06-08-2014, 11:46 AM
I wasn't too concerned about shearing. Working on big tractors all day I got a pretty good understanding of steel strength. My life depends on it. Just the fact it bent after one use was reason enough to not use it again. Went back to using the pin that came from who knows where and never had an issue with it.
