Old 08-02-2015, 09:57 AM   #11
Marine3038's Avatar
Name:	ImageUploadedByForest River Forums1438527433.340561.jpg
ID:	84779. There she is!
Marine3038 is offline   Reply With Quote
Old 08-02-2015, 10:02 AM   #12
wmtire's Avatar
If you have the three valve system, for normal use, you want the cold water inlet valve open, the hot water outlet valve open, and be sure to have the bypass valve closed (which ties the cold water and hot water lines together).
Normally, the T-handles will indicate the position. If the handle is parallel with the line, then it's open, and if the t-handle intersects the line, it is closed.
It's easy to confuse the open/closed positions, especially on the bypass valve, since that line is usually running vertical compared to the horizontal cold/hot water lines.
Here is a diagram for normal use vs winterization mode.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-02-2015, 10:04 AM   #13
Marine3038's Avatar
Awesome info - thanks for posting. Fixed the issue - hope this thread is useful to anyone having the same issue (which is pretty much operator error
Old 08-02-2015, 01:01 PM   #14
bikendan's Avatar
actually, it's pretty common in areas that require winterizing.
dealers sell units still in winterizing mode to newbies that don't know or owners winterize and forget to turn the valves back to normal.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-02-2015, 03:26 PM   #15
Thunderbolt75's Avatar
I've been using a bright orange tag wired to my cabinet handle for years. It reads "Water heater empty, bypassed. Fill tank before lighting"
It is cheap insurance for my electric element and is infinitely reusable.
2016 Surveyor 191T (pending delivery)
2006 KZ 37KGx2
2005 Dodge 3500 4x4 CTD
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
hot water, water
