Old 08-02-2015, 08:21 AM   #1
Marine3038's Avatar
Hot Water
We are camping in North Florida and having some issues with our hot water (2014 233s model).
Cold water is flowing through the sink, bathroom sink and outside shower; however, there is no water flowing out the hot water side.
Any suggestions on what I need to troubleshoot?
Marine3038 is offline   Reply With Quote
Old 08-02-2015, 08:25 AM   #2
Done with this
Check the bypass valves. You must check from the inside of the camper by removing the panel behind the WH.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 08-02-2015, 08:26 AM   #3
Done with this
The WH is in the bypass position shown here.
Old 08-02-2015, 08:32 AM   #4
nomad297's Avatar
If this is something that just happened -- yesterday you had water and today you don't -- you probably have a defective/stuck check valve at your water heater.
Bruce
Old 08-02-2015, 09:04 AM   #5
Marine3038's Avatar
Thanks for posting! Not sure how to access this on my model - I can access the water filter from inside but don't see an access point to get to this?
Old 08-02-2015, 09:15 AM   #6
Marine3038's Avatar
Bruce
Thanks for posting, Bruce --- no the hot water was not working yesterday - the only time we can get water is if we use the cold water handles (hope that makes sense)
Old 08-02-2015, 09:20 AM   #7
nomad297's Avatar
How long has this been a problem?
Bruce
Old 08-02-2015, 09:24 AM   #8
Marine3038's Avatar
Bruce
This our first trip in a while (the unit was shipped back to the factory for repairs)... so this is the first time we noticed it wasn't working.
Any idea how to access the hotwater bypass valve?
Old 08-02-2015, 09:32 AM   #9
nomad297's Avatar
Where is the water heater on the 233S? What is on the other side of it inside of the camper? That's where you need to get to.
Bruce
Old 08-02-2015, 09:39 AM   #10
Marine3038's Avatar
Was able to get to it (really awkward in my model - underneath the couch w/ no real access panel).
Have water flowing now- just have to play with the valves to see which combo gets the water hot!
Love this forum!
Old 08-02-2015, 09:57 AM   #11
Marine3038's Avatar
Name:	ImageUploadedByForest River Forums1438527433.340561.jpg
ID:	84779. There she is!
Old 08-02-2015, 10:02 AM   #12
wmtire's Avatar
If you have the three valve system, for normal use, you want the cold water inlet valve open, the hot water outlet valve open, and be sure to have the bypass valve closed (which ties the cold water and hot water lines together).
Normally, the T-handles will indicate the position. If the handle is parallel with the line, then it's open, and if the t-handle intersects the line, it is closed.
It's easy to confuse the open/closed positions, especially on the bypass valve, since that line is usually running vertical compared to the horizontal cold/hot water lines.
Here is a diagram for normal use vs winterization mode.
2011 Flagstaff 831 RLBSS
Old 08-02-2015, 10:04 AM   #13
Marine3038's Avatar
Awesome info - thanks for posting. Fixed the issue - hope this thread is useful to anyone having the same issue (which is pretty much operator error
Old 08-02-2015, 01:01 PM   #14
bikendan's Avatar
actually, it's pretty common in areas that require winterizing.
dealers sell units still in winterizing mode to newbies that don't know or owners winterize and forget to turn the valves back to normal.
Old 08-02-2015, 03:26 PM   #15
Thunderbolt75's Avatar
I've been using a bright orange tag wired to my cabinet handle for years. It reads "Water heater empty, bypassed. Fill tank before lighting"
It is cheap insurance for my electric element and is infinitely reusable.
2016 Surveyor 191T (pending delivery)
2006 KZ 37KGx2
2005 Dodge 3500 4x4 CTD
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
hot water, water
