Old 05-08-2014, 06:35 PM   #11
Originally Posted by kenandterry View Post
Personally............the OP should find another dealer for his RV concerns.
Guys like him give the business a bad name. A dealer would be better off to admit he doesn't know than lead you down the garden path with a story like his.
It's a shame they do that kind of stuff. Good thing there is the internet with forums like this. The dealer we bought our coach from will get nothing but incoming fire from us. I'll give you the shirt off my back until you try to cheat or lie to me. Like I said, it's a shame.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-09-2014, 10:59 AM   #12
urocav2001's Avatar
Yeah this camper store is a joke!!! They go thru service reps like water, none seem to know any info of campers..
urocav2001 is offline   Reply With Quote
Old 05-09-2014, 11:08 AM   #13
VinceU's Avatar
To answer your question why does it neck down? As the metal breaks down it generates a small current, the shortest path to the opposite polarity is the head of the plug and rod connection. All anodes breakdown there first.
Old 05-09-2014, 12:32 PM   #14
Good information. Thanks.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 05-09-2014, 02:16 PM   #15
Sacrificial anode
No first hand experience on these RV units, but I just picked up a new RV and my tech said replacing every year was typical. This of course depends on water quality and I'm guessing many folks replace sooner than needed as it "looks" used. As a now retired engineer, I will say that as long as you have sacrificial molecules, you are OK. When they are gone, the tank will corrode quickly. Looks like you may be better than average and have a couple of seasons left. I think this is roughly a $ 10 - 20 replacement part. I'll probably pick up one and carry as a spare for when mine needs replaced. I did not look at the offered material while I was in the store but see a lot of Aluminum and Aluminum alloy on line as well as Magnesium. Magnesium would give the best protection (cost the most) and corrode the fastest. Pure Al would be cheapest, corrode slowest, and give the least cathodic protection. So not looking "new" after one season could be a good thing and shows the tank is being protected from corrosion, and the sacrificial anode is working as designed !
richl167 is offline   Reply With Quote
Old 05-09-2014, 02:49 PM   #16
Originally Posted by richl167 View Post
(I) ... see a lot of Aluminum and Aluminum alloy on line as well as Magnesium. Magnesium would give the best protection (cost the most) and corrode the fastest. Pure Al would be cheapest, corrode slowest, and give the least cathodic protection.
Is aluminum alloy somewhere in between?
- 2000 Coleman Mesa
Old 05-09-2014, 07:12 PM   #17
Yes. sometimes a little tin or zinc is added to the al for water heater catholic protection. I don't think it changes the cathodic protection much but can combat sulphur if it is in the water and give a better taste/smell to the water. Again, for these RV ones would have to check what materials are actually available.
Old 05-09-2014, 07:34 PM   #18
So, if Al alloy are available and don't change the cathodic protection but offer some benefit with respect to taste and smell, it seems they might be better for RV applications? I draw that conclusion from the fact RV owners are exposed to a variety of water qualities, including smelly sulphur water. That assumes that Al alloy is sufficiently protective, even if not as protective as Mg.
- 2000 Coleman Mesa
Old 05-09-2014, 07:50 PM   #19
VinceU's Avatar
Chris before you get too tangential, l let me just add a fellow camper in the resort we were in developed a horrible odor/taste at all his hot water outlets. I've never seen it this bad. I diagnosed it as bacteria in his hotwater tank. The unit was less than a year old but I'd see the problem in homes. Had him thoroughly flush the heater out then applied a 50/50 solution Of Chlorine bleach directly into the heater via the relief valve. Took two applications but the "bugs" were killed and heater resumed. Anodes have no relation to taste or smell, only bi-metal reactions.
Old 05-10-2014, 09:15 AM   #20
materials
A little zinc mixed in with the Al allows the zinc molecules to bond with sulphur (if present) and form zinc sulphide. This is a stronger bond than the hydrogen in H2O forming hydrogen sulphide. Personally, if I were at a campground with a strong sulphur smell in the water, I would move or get some bottled water. Above is correct in that the zinc might help sulphur in the water but not bacteria. That is a wholly different problem. I plan to look for magnesium and then buy aluminum if I cannot find Mg as a spare. Pure Al or Alloy Al about equal in my book. As long as you don't skip the maintenance and check that material is actually left, tank should last fine.
heater, hot water, water, water heater
