Old 05-08-2014, 02:47 PM   #1
urocav2001's Avatar
Hot water heater
Name:	ImageUploadedByForest River Forums1399578381.178437.jpg
Any suggestions on how this happened? It's only one season old, just got unit back from winterization and it was still out of the heater.. Should I buy a new one service rep is telling me it's only a drain plug?!?!
urocav2001 is offline   Reply With Quote
Old 05-08-2014, 02:52 PM   #2
Looks pretty good for one season. It still has lots of life left in it. Don't forget to use Teflon tape when you reinstall it.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-08-2014, 02:52 PM   #3
Good for another year! Youroo!!
Old 05-08-2014, 03:11 PM   #4
urocav2001's Avatar
Ok so it's suppose to be about half the diameter near the head? It looks like it's very skinny and brittle near the bolt
Old 05-08-2014, 03:13 PM   #5
wmtire's Avatar
Lou has an anode rod usage chart in the FAQ section:
Anode facts and FAQs
If anyone tells you the anode rod is JUST a drain plug on a Suburban brand water heater, they need to educate themselves more.
Sacrificial anode rod protects your water heater tank from corrosion by attracting corrosive elements in water, so they attack the anode rod rather than your water heater tank interior.
Simply remove the anode rod from the tank and inspect it every three months. If it is mostly eaten away, replace it with a new one to extend the life of the tank.
To answer your original question, as others have stated you still have much life left in that one pictured. How long an anode rod last depends a lot on the content of the water in the tank, which is different in different parts of the country, municipalities, etc.
You had concerns about it being brittle near the bolt head. There is a metal rod that goes thru the entire length as you can see in the usage chart at 100% usage, so it's not going to break.
Here are some more pics so you can see this better:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-08-2014, 03:33 PM   #6
B47
Originally Posted by urocav2001 View Post
Attachment 51979
"It's only a drain plug?" - what else has your service rep told you?
It's your water heater anode rod that's attached to a drain plug for removal,inspection and replacement when necessary.
I'm often amused when people ask how could their water heater anode rod could deteriorate so fast for the following reasons:
1. There is no hard and fast rule regarding how fast these deteriorate - it depends on the mineral content of the water that is going into the water heater. If it's "soft" water,the rod will last longer that one in a water heater that "hard" water is used in.
2. As the rod deteriorates it's only doing it's intended function - its role is to "sacrifice" itself so the harmful minerals in the water attach it and not the water heater tank itself.
As stated - a chart showing the various stages of deterioration of these rods is posted and should be your guide in determining when you should replace the rod.
Old 05-08-2014, 03:44 PM   #7
iceblaze580's Avatar
Attachment 51979
Mine looked a lot worse than that after one season yours is good for at least another season
iceblaze580 is offline   Reply With Quote
Old 05-08-2014, 06:14 PM   #8
Yup, OPs still has resale value. Ours looked worst after 5 months. He must have good water in his area.
Old 05-08-2014, 06:22 PM   #9
kenandterry's Avatar
Personally............the OP should find another dealer for his RV concerns.
Guys like him give the business a bad name. A dealer would be better off to admit he doesn't know than lead you down the garden path with a story like his.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-08-2014, 06:26 PM   #10
B47
X2 - don't ask him how your water heater bypass valve works or where it's located.
heater, hot water, water, water heater
